Toyota Yaris/Echo Door /Trunk Trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70022
Printed Date: May 15, 2024 at 7:39 PM
Topic: Toyota Yaris/Echo Door /Trunk Trigger
Posted By: Sungura222
Subject: Toyota Yaris/Echo Door /Trunk Trigger
Date Posted: January 04, 2006 at 10:56 AM
I'm trying to locate the Door & Trunk triggers on my 2003 Yaris (Echo in US). Where can I find these wires & what colour are they? Correct me if I'm wrong, the trigger in the Yaris is Negative trigger. As I've got a door /trunk open indicator on the dashboard, I know I have to use Diodes, but how do I wire it up. Any Help much appreciated. Kind Regards A.P. ------------- (;-)
Posted By: Jschult3
Date Posted: January 04, 2006 at 12:33 PM
Yes they should be a negative trigger and you should only use diodes to seperate the front door triggers. The trunk should have it's own pin and wire. Check out the relay section for "isolating a negative trigger" the cathode just has to be pointing the right way for it to work. https://www.the12volt.com/diodes/diodes.asp What I normally do is tie the ends of the diodes together and then connect them to their respective door trigger, all nicely wrapped up with heat shrink tubing. Not sure about colors but using a DMM you should see a negative reading when the door is open and 0.00 when the door is closed. You may have to check directly at the pin, which is a pain but it's better than checking every wire in the harness's. Good Luck! ------------- Jeff
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
Date Posted: January 04, 2006 at 1:59 PM
Thanks for that info, I'll look for the wires using multi meter. ------------- (;-)
Posted By: smajz
Date Posted: January 04, 2006 at 3:04 PM
Hi everybody!!! I´m a new member, I´m from Mexico city but currently I study at UCSB. Hereby I introduce my self and ask you some questions. My brother and I are considering to install an alarm in a VW golf MK2. We have put a lot of effort (we rebuild the car by our own) and money in this car , so we want to buy a reliable and affordable alarm or security system. Do you have any suggestions, brands, accesories? The items in the market are so diverse that it´s very easy to get lost. What features should I consider before buying an alarm? I´m sorry I had to reply one of your posts, I tried to start a new topic but I do no why I couldn´t. Thanks in advance, I really appreciate your help ------------- All that is solid melts into air, all that is holy is profaned, and man is at last compelled to face with sober senses his real condition of life and his relations with his kind.
Posted By: 05gt
Date Posted: January 04, 2006 at 10:00 PM
hey Sungura222 the doorpin wire is negative trigger and is PINK, this wire is higher up in the driver kick panel in a 8 pin plug as for trunk pin, it doesn't have a seperate wire for it, if, when you open the trunk and it controls the domelight then it should work in conjunction with the doorpin wire if not then you will have to ass your own pin
Posted By: secureauto
Date Posted: January 04, 2006 at 10:08 PM
According to DEI door trigger is RED / white at fusebox and RED / blue for trunk in driverside kick panel.
03 Echo------------- ASE Certified
Posted By: 05gt
Date Posted: January 04, 2006 at 10:13 PM
sorry PINK is the domelight supervision wire you can diode isolate the door trigger wires left front door is red, right front door is blue, left rear door is green, and the right rear door is blue these wires are in a 30 pin plug in the top left od the fusebox trunk pin is lt. blue and it is in the same plug as the doorpin wires
Date Posted: January 16, 2006 at 5:55 AM
Thank you, your help much appreciated, and has saved me time you can diode isolate the door trigger wires left front door is red, right front door is blue, left rear door is green, and the right rear door is blue these wires are in a 30 pin plug in the top left od the fusebox trunk pin is lt. blue and it is in the same plug as the doorpin wires [/QUOTE] ------------- (;-)
Posted By: Powermyster
Date Posted: January 16, 2006 at 7:56 AM
cobra list a RED / yellow in the 25 pin connector for c/l unit says install switch for the boot. thats for a '01 and on yaris
------------- Why oh Why didn't i take the blue pill
Darren Power
