2001 passat remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70755
Printed Date: May 18, 2024 at 6:11 PM
Topic: 2001 passat remote start
Posted By: jim141
Subject: 2001 passat remote start
Date Posted: January 14, 2006 at 1:17 PM
need the wire color , location and direction for connecting the alarm disarm wire from RS to this car. thanks jim
Posted By: Velocity Motors
Date Posted: January 14, 2006 at 3:01 PM
You need to get into the door for the OEM alarm disarm. Pulsing the unlock wire once will disarm the system and 2 pulses will unlock.
------------- Jeff
Posted By: jim141
Date Posted: January 15, 2006 at 9:07 AM
Would you be able to offer wire color and would this wire be in the cluster coming from the door key switch? Thanks, Jim
Posted By: anickle
Date Posted: January 15, 2006 at 11:48 PM
disarm and arm are same as lockand unlock so you will need to double pulse unlock in the door colours are lock RED / green and unlock RED / blue(test to verify) They are both neg in the door. Inside door DO NOT pull off the bigmetal plate it is not a good idea
------------- andrew nickle
Posted By: gus1
Date Posted: January 16, 2006 at 11:37 AM
And why would you pull the inner door insert Andrew??? Realigning the window regulator is NOT fun.....
Test the door lock wires using the key in the outside door chamber.... extended pulses will close sunroof/roll up windows, and roll down the windows. Doorpin, hoodpin, trunkpin, trunk release are all at the BCM, located under the carpet in front of the driver's seat.
Gus
------------- Wherever I go, that is where I end up......
Posted By: jim141
Date Posted: January 16, 2006 at 6:10 PM
Thanks for the door lock help guy's, but now having problems with a designtech bypass module. Works sometimes, but sometimes not. Any tips? Thanks, Jim
Posted By: OhioMike1101
Date Posted: January 16, 2006 at 8:00 PM
Buy something else.... Designtech is junk.. Even the rebadged DEI crap. ------------- South Side Audio
2501 S. High St
Columbus, OH 43207
Posted By: anickle
Date Posted: January 16, 2006 at 9:10 PM
not familliar with the designtech bypass, is it a c**k ring thingy that goes around the key cylinder? use a DEI 555U/w and hard wire it(too bad you lose a key). In the install book it has alternate wiring instructions, the passat should have a twisted pair of wire coming from behind the cluster that you can hardwire the U into. If the designtech can be wired this way try it as well. should work a lot better
