99 Suburban domelight stays on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71042
Printed Date: May 29, 2024 at 12:56 AM
Topic: 99 Suburban domelight stays on
Posted By: Zebrafive
Subject: 99 Suburban domelight stays on
Date Posted: January 18, 2006 at 12:49 PM
The domelight will not shut off on my 99 Suburban unless you start the engine, use the domelight override switch or pull the fuse.
It used to shut off after about 15 seconds. I am thinking it might be the keyless entry module. Where is it located? I want to unplug it and see if that is the problem.
The other thing may be a bad door switch. What is the best way to check them?
Posted By: mike swanson
Date Posted: January 18, 2006 at 1:12 PM
1st check to see,,,IM NOT SAYING YOU DUMB or anything like that. but check to see if the dome switch is on.
I think they have 2 diff switches and also it can be programed to do diff things.
This is a -trigger so somthing could be grounding the dome lite to stay on.
Has any1 worked on it? putting a remote start on or any headliner work????
Posted By: brcidd
Date Posted: January 18, 2006 at 2:43 PM
I saw a 99 Tahoe do the same thing- it was the dome light supervision module- mounted dead center in the dash just above the console- it was about $96 to replace- so owner opted for a module from a bone yard- owner ran with the override switch turned on- so the lights would stay off....
Brcidd - Engineer That Does Remote Starter Installs on the side.
Date Posted: January 19, 2006 at 11:14 AM
Domelight switch (thumbwheel to right of headlight switch) was first thing I checked. You can turn on the domelights with it, even with the domelight override button engaged.
Not aware of two switches, unless you mean the thumbwheel and domelight override buttton. Could not find anything about programing in my owners manual
There may be a door switch gone bad or wire going to ground causing this problem.
Headliner has never been worked on. No remote start. Only electrical work is a trailer brake controller.
Date Posted: January 19, 2006 at 11:20 AM
This sounds like it may be the problem. Do you have any more info? Part #? How to ID so I can look for in the salvageyard?
Do you know if this Tahoe has keyless entry? Seems someone told me if you have keyless entry it controled the domelight delayed shut off. Thats why I was thinking the keyless entry module might be bad.
Posted By: brcidd
Date Posted: January 19, 2006 at 2:41 PM
FIGURE Interior Lamp Control Module(c)
posted_image
posted_image
(1)Remote Control Door Lock Receiver Module
(2)Interior Lamp Control Module
(3)Transfer Case Control Module
Interior Lamps System Check
Step
Action
Normal Result(s)
Abnormal Result(s)*
1
Place the courtesy lamp switch in OFF.
All of the interior lamps are off.
2
Place the courtesy lamp switch in ON.
The courtesy lamps turn on.
3
Open and close each door one at a time.
  • The courtesy lamps turn on for approximately 25 seconds.
  • The courtesy lamps fade out each time.
4
Press the unlock button on the keyless entry transmitter.
  • Courtesy lamps turn on for approximately 40 seconds.
  • Courtesy lamps fade out.
5
  1. Open the IP compartment.
  2. Close the IP compartment.
The IP compartment lamp turns on once the compartment is open, then turns off when the compartment is shut.
Instrument Panel (I/P) Compartment Lamp Inoperative
6
  1. Turn each reading switch to ON.
  2. Open each sunshade mirror cover.
  3. Close each sunshade mirror cover.
  • The reading lamps turn on.
  • The sunshade mirrors lamp turn on.
  • The sunshade mirror lamp goes out.
Vanity Mirror Lamp(s) Inoperative
7
Place the headladlamp switch in the PARK position.
  • The component illumination lamps light.
  • The ashtray lamp lights.
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Date Posted: January 22, 2006 at 11:08 AM
Thanks for posting the drawing of the Modules. I assume they are located somewhere under the dash.
The Interior Lamps System Checks would not let me open the links to Abnormal Results. I get a message "Access Forbidden"
