1997 Tahoe remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71226
Printed Date: June 09, 2024 at 3:05 PM
Topic: 1997 Tahoe remote start problem
Posted By: huntinfla
Subject: 1997 Tahoe remote start problem
Date Posted: January 21, 2006 at 3:01 PM
Ok, here's the problem. I have a 1997 Tahoe and I installed a Viper 791vx today. The alarm portion works fine, doors unlock and lock as they should, but when you go to remote start it, the truck will crank, but never start. It cycles like this until I press tha beake pedal or cancel the remote start. I have been racking my brain trying to figure this out. I have hooked up the ignition wires properly, and all my dash stuff works, it just wont start. Anybody got any ideas? Oh, one more thing, my remote doesn't receive the signal from the alarm module, when I press the lockk button on the remote, the truck locks and the alrm beeps, but the remote beeps like it didn't receive an answer from the alarm. It does this for all functions of the alarm. Thanks for any help................
Posted By: kgerry
Date Posted: January 21, 2006 at 3:44 PM
did you learn tach??? this will happen if you dont learn tach to the unit BEFORE you try it..... for the communication probelm try to unplug the antenna for 5 minutes and plug it back in..... make sure you have all functions and features connected before you start testing or trying things...... ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Mike M2
Date Posted: January 21, 2006 at 4:49 PM
What type of bypass did you install for the Passlock2 system? It sounds like it's not working...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: au5599
Date Posted: January 21, 2006 at 5:22 PM
1997 did not have passlock II. Started in 1998. Did you tach learn? You got all the outputs properly including the 2nd ignition?
Date Posted: January 22, 2006 at 3:26 PM
Ok, now I finally got the remote start to fuction properly, and everything works fine, EXCEPT my remote still does not receive any thing from the vehicle so I always get the beeps when I press any button on the transmitter. (Even though the alarm arms/disarms and starts) I tried disconnecting the antenna like Kgerry suggested, but still doesn't work. Any ideas? Thanks for the help guys...........
Posted By: another-kelly
Date Posted: January 22, 2006 at 9:59 PM
possibly bad remote. seen that before, progammed new remote and it worked fine
Date Posted: January 23, 2006 at 5:26 PM
Ok, I programmed my remote to my sons truck, and it functions fine. However, his remote doesn't receive any signal from my system. ANy ideas? Help!!!!!!!!!!!!!!!!!!!
Posted By: Scott35
Date Posted: January 23, 2006 at 5:28 PM
How long did you leave the antenna unplugged?
------------- Tacomacrew
Date Posted: January 24, 2006 at 2:23 PM
I left the antenna unplugged for 10-15 minutes.
Date Posted: January 25, 2006 at 10:08 AM
Anyone? This is killing me, I need to know what part (if any) that I need to replace.
Date Posted: January 25, 2006 at 1:43 PM
try swapping the ant with you sons
Date Posted: January 25, 2006 at 5:59 PM
I already tried that, still no luck...................
Date Posted: January 25, 2006 at 9:34 PM
you you also try the ant cable?
Posted By: diva
Date Posted: February 08, 2006 at 10:36 PM
That happened to me after my battery died in my 03 tahoe. one of my installer buddies told me to unplug the antenna, start the car, then plug the antenna back in while the car was running. no probs after that. make sure your antenna is plugged in all the way at the brain
