Is red always hot and black ground?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71345
Printed Date: October 31, 2024 at 6:13 PM
Topic: Is red always hot and black ground?
Posted By: geaux
Subject: Is red always hot and black ground?
Date Posted: January 23, 2006 at 12:55 PM
Are these statements always true?
A 12 guage wire that is RED without any strips is HOT + . It will be hot even without the car turned on.
A 12 guage wire that is BLACK without any strips is GROUND -.
------------- He is mad, mad I tell you!
Posted By: sk8ingsmurf
Date Posted: January 23, 2006 at 1:48 PM
Unless somebody messed with the wiring factory wiring is always black=ground, and you could sorta say red is hot. From the battery yes red is hot, but on a deck red is switched 12v (yellow is hot in this case).
Posted By: fingaz22
Date Posted: January 23, 2006 at 1:49 PM
no not always true. exspeacily in a vechile wiring harness. always double check your wires before you commit to anything!!! in most instances they will be in that gauge wire. but always beware. ------------- JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
Posted By: the12volt
Date Posted: January 23, 2006 at 1:55 PM
No, black is not always ground and red is not always "hot", with or without stripes. ------------- the12volt • Support the12volt.com
Posted By: godblessdremil
Date Posted: January 23, 2006 at 2:21 PM
For a component bieng added like a remote start that is usually true. But in factory wiring in the car no, infact its usually wrong.
Posted By: kgerry
Date Posted: January 23, 2006 at 2:31 PM
THE THICK RED WIRE GOING TO FORD RADIOS IS THE GROUND....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: geaux
Date Posted: January 23, 2006 at 2:32 PM
Okay I can understand that sometimes wires of different colors can be positive (12V+) or ground but has anyone ever seen an instance of a solid red wire not being hot and a solid black wire not being ground?
My car is an 1997 ford. Assume that nobody has messed with the factory wiring.
Posted By: gus1
Date Posted: January 23, 2006 at 2:33 PM
Dammit Kevin... you beat me to it.
Then, there are things that use white for ground.... orange for 12V.....
A DMM is your best friend.
Gus
------------- Wherever I go, that is where I end up......
Posted By: geaux
Date Posted: January 23, 2006 at 2:35 PM
I guess kgerry answers that question. Moral of the story is to check first.
While I am being on an idiot roll let me continue. I can use a test light probe to see if a wire is positive. Stick the probe to the wire and it will light up if it is hot? How can tell if a wire is a ground?
Posted By: kgerry
Date Posted: January 23, 2006 at 3:31 PM
first by throwing your test light in the garbage and getting a meter.... then doing the exact opposite with the meter when testing for a negative.... apply 12 volts to the positive lead and probe with the negative lead.... ------------- Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: dualsport
Date Posted: January 23, 2006 at 4:33 PM
Yeah, test lights have their uses, but not for random probing of unknown wires- if you tap into the wrong thing, you could blow things up.
Definitely stick with a DMM for doing your exploratory, which is much safer, doing as Kevin instructed.
Posted By: auex
Date Posted: January 23, 2006 at 5:08 PM
Generalizations are bad and can cost thousands for making an assumption. Black is not always ground and isn't ground in european cars. Then again you should never tie into a factory ground unless you are replacing something(radio for instance). As far as red being power, how often do you see a wire without a stripe anymore? ------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: January 23, 2006 at 5:30 PM
Man Im really sorry I was just completely not thinking when I answered your question, listen to these guys they are definitely right. Assuming this can easily mess up your electrical system. Sorry for the confusion and please disregard my entire post.
