1999 WRX, Viper 791xv Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72482
Printed Date: May 15, 2024 at 3:17 AM
Topic: 1999 WRX, Viper 791xv Alarm
Posted By: pracy
Subject: 1999 WRX, Viper 791xv Alarm
Date Posted: February 09, 2006 at 1:36 AM
Hey all,
I have been looking through the forums getting some info over the past couple weeks as we just brought a aussie model, silver 99 wrx sedan in stock condition... So far we have put a full 3" stainless xforce exhaust turbo back and a GFB plump-back BOF... also things like all oils,timing belt etc were done also. Next are some 18"x7.5" wheels, we just can't decide what ones posted_image
We came across a Viper 791xv at a good price and I am going to install it. The only new thing i am attempting is taking the wrx interior apart and the remote start feature... I have a couple questions i am hoping someone can clear up? cheers
-What immobilizer interface module (bypass module) should I use? I can't seem to find much info for these units... The book says 555U but I can't find that anywhere todo with subaru. I can find them at ;
https://www.caraudio-caralarms.com/555U.html
https://www.caraudio-caralarms.com/556U.html
-I have found a wire map for 04' and 05' wrx but nothing older. Does anyone have one? would be ofcourse a great help!
-As for the remote start, Does the ECU in the 99' have a pin-out giving ground in Neutral like I have read about in the newer wrx's?... this would allow me to use the remote start feature completely safely.
the wire map would save alot of time, I have also read a bit about where the best point is to grab the tacho learn, What is everyone choice here?
Someone had found a point right near the coils but I have misplaced the info..
thankyou all
Posted By: JWorm
Date Posted: February 09, 2006 at 10:01 AM
Not many people here are going to have info on Austrailian cars. Might want to do some research over at nasioc.com or any Subaru forums specific to Australia.
Posted By: iskidoo
Date Posted: February 09, 2006 at 3:07 PM
Are these better known as an Impreza? If so I have this diagram for it which is the UK version.
DIRECTWIRE™ WIRING INFORMATION - SUBARU / IMPREZA (UK) / 1999 / Remote Start
12volts Go to the battery
Starter blue/red      ignition harness
Second Starter
Ignition red      ignition harness
Notes: Fuel pump cut is BLACK/ red in o/side kickwell in taped loom to rear of car.
Second Ignition
Third Ignition
Accessory RED / yellow      ignition harness
Second Accessory
Keysense
Power Lock white    F   driver side kickwell
Power Unlock same wire
Lock Motor
Unlock Motor
Parking Lights+ grn/yel & grn/red     steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / wht or tan/wht    -   steering column
Notes: One model uses a yellow wire in the driver kick panel, negative trigger.
Dome Supervision
Trunk/Hatch Pin YELLOW /GREEN      at the bootlight
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue      top of engine
Notes: Also blue/green at clocks.
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Steve G
Posted By: pracy
Date Posted: February 09, 2006 at 11:06 PM
thanks guys, i have been looking for info around aussie based sites also..
thankyou iskidoo, cheers.
Hers- 99' Silver WRX Sedan -3" xForce stainless turbo back + GFB BOF
His- 82 XE 351c 300+KW
