Alarm still arms with open zone!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73330
Printed Date: May 03, 2024 at 2:58 PM
Topic: Alarm still arms with open zone!
Posted By: cjastacio
Subject: Alarm still arms with open zone!
Date Posted: February 22, 2006 at 7:20 PM
I just finished installing a Crimeguard 533i4 on my new 2006 Scion xB and have a problem. I can arm the alarm with one or any of the doors open. I did use a DMM to verify the wire before the install but noticed something about the voltage differences. When the door(s) were open the DMM showed 0.01 or 0.02 and I thought that could be okay and when they were closed it would show 9.54 which I thought was also fine. Now, I have this problem. The other interesting thing is that any other behaviors regarding the doors behave normally. The alarm won't rearm unless all doors are closed, it does confirm when all doors are closed, and the alarm does go off when one of the doors is opened. Any suggestions? By the way, the wire I used for the door trigger was the same one I found on this site and was confirmed on other sites.
Posted By: Hornshockey
Date Posted: February 22, 2006 at 7:29 PM
your alarm should still arm with one or more doors open. It will bypass the door trigger, until such time as it sees the doors are closed. Then it will begin monitoring the doors.
------------- Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Posted By: ringojam
Date Posted: February 22, 2006 at 8:31 PM
SHURE YR NOT USING + DOOR TRIGGER IT SEEMS THAT WAY ------------- Jamaica home of the worlds fastest man.
Posted By: Ravendarat
Date Posted: February 22, 2006 at 9:20 PM
Ya the alarm apears to function fine from my point of view. The alarm will bypass the door zone and just use the shock sensor and ingition sense to actually set off the alarm. I dont think I have ever worked with an alarm that wouldnt arm with the door sensor open.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: February 23, 2006 at 2:25 AM
I am pretty positive I am using the negative door trigger, although I will double check the install instructions for my alarm. The thing I am concerned about is that when I do arm and one of the doors are open shouldn't my alarm give me some sort of confirmation that it had to bypass a zone to arm? It does this with my hood pin switch. I will double check the instructions and wiring.
