1999 Silverado remote starter problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73462
Printed Date: May 05, 2024 at 3:13 PM
Topic: 1999 Silverado remote starter problems
Posted By: hummerr6
Subject: 1999 Silverado remote starter problems
Date Posted: February 25, 2006 at 9:41 AM
Have a 1999 Chevy Silverado w/ remote starter, that locks out regularly 1 a week. I like to find out how to
RIP the #*@% out.  I think it was put in by DUKE'S Car Stereo. TIA
hummerr6
Posted By: xtremej
Date Posted: February 25, 2006 at 9:45 AM
Do you mean it won't start.. What kind of remote starter, Ignition bypass?
Posted By: hummerr6
Date Posted: February 25, 2006 at 9:53 AM
Yes, it locks out for 10 min and then i can start it. I like to rip the thing out. I dont know what kind it is , i will be checkin today. It uses a DEI remote 471T. I know nothing about them.
hummerr6
Posted By: xtremej
Date Posted: February 25, 2006 at 10:00 AM
It probably has a 555l ign. bypass. You'll have to find the passlock wires yellow and orange w/black stripe  the yellow will be cut, just solder this one back together. Then just remove the rest of the system. Have you tried taking it back to were it was installed, most dei products carry a warranty. Most shops also warranty their work to, I do...
Posted By: wiretapper
Date Posted: February 25, 2006 at 9:24 PM
Don't be so quick to rip it out. Make sure it's not the ign switch itself. This was a known problem on '99-01 Silverados. The insides if the ign switch that control the Passlock are plastic and wear out, making the security light come on while driving. Also the same symptom you're having. Just giving you a heads up.
Posted By: audioxtacy916
Date Posted: February 27, 2006 at 11:11 AM
Do exactly what he said..Well first take it back to the installers and have them fix it. Sounds to me like they put the resistance side of the 555L to the wrong side of the passlock wires. Another possiblity is that the 555L is just a bad one and it needs to be replaced. But if all else fails and you don't wanna go back to those guys, just put that yellow wire back together and your truck should start back up.
Posted By: audiophd
Date Posted: February 27, 2006 at 12:33 PM
i have seen problems especially on GM vehicles. durring crank it drops voltage which sometimes makes the DEI part loose memory until started by key again. if nothing else try peripherals part number ppldata their interfaces are good until 9.42 volts
Posted By: hummerr6
Date Posted: February 28, 2006 at 6:33 PM
Thanx Guys, it is doing everything that yhou have said: secutrity light coming on, I removed one of the fuses and KNOCK on wood it seems to be working ok. It is a 555L DEI . Does anyone have the install instructions & disconnect ones too? I like to take a look to see how they install them. I design the instrument clusters for Delphi Automotive, so it might be good to KNOW!!!!! THANX AGAIN
hummerr6
Posted By: xtremej
Date Posted: March 01, 2006 at 10:30 AM
pass lock II wiring for 555lw on 99 chev truck
harness from 555lw
red   constant 12 volts
pink primary ignition wire
violet --no connection
blue/black  - negative status out from remote start
black passlock ground goes to ORANGE / black ignition harness just clear insulation on wire and solder in.
BLACK/ white no connection
yellow goes yellow ignition harness usualy right next to ORANGE / black, cut the yellow wire ign. harn. solder 555lw wire to key cylinder side of wire
BLACK / YELLOW solder this to the other side of the yellow passlock wire.
Make sure to start with key and let it run for a minute, dei says it programs in 5 sec but this is not true sometimes.
It is always better to solder these connections, if they fail your vehicle will not start..........happy hunting.
