AutoLok VIP, 1999 Dodge Caravan
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73582
Printed Date: May 20, 2024 at 7:34 PM
Topic: AutoLok VIP, 1999 Dodge Caravan
Posted By: 323cid
Subject: AutoLok VIP, 1999 Dodge Caravan
Date Posted: February 27, 2006 at 9:32 AM
I have a 1999 Dodge Caravan with the AuoLokVIP installed.
The unit was in the vehicle when I bought it. Problem is that the dealer didn't have the codes so they have it unhooked.
Tried plugging it back in and tried the master code to reset it, no luck. Any suggestions would be greatly appreciated. Thanks
Posted By: mrcllusb
Date Posted: February 27, 2006 at 9:43 AM
So you tried the factory master code from the manual?
------------- "ole blake"
Posted By: 323cid
Date Posted: February 27, 2006 at 9:47 AM
Factory manual = 747#
Posted By: mrcllusb
Date Posted: February 27, 2006 at 10:16 AM
No that's the access code..You enter that first then the master code..
Posted By: mrcllusb
Date Posted: February 27, 2006 at 10:19 AM
Try this and tell me if it works.First 747# then 1111*,01# then your new 4 number code then *
Posted By: 323cid
Date Posted: February 27, 2006 at 10:52 AM
Tried as per inst. 747# gives a steady red next steps give flashing red with no luck.
Question? With key on or off?
Posted By: mrcllusb
Date Posted: February 27, 2006 at 10:59 AM
The light starts flashing red when the system has been activated.It activates 15sec after the engine is turned off.Try this.Let the system arm,then go thru the steps to try and change the code,without the key on..
Posted By: 323cid
Date Posted: February 27, 2006 at 11:28 AM
Received code from dealer. Old code works, Yea.
Next I will find a way to put new codes in as I didn't have any luck changing them.
Thanks for the help. Great fourm.
Posted By: mrcllusb
Date Posted: February 27, 2006 at 4:47 PM
You're welcome anytime..
