im trying to install a radar sensor i bought from asianwolf.com... i have a single stage shock sensor but im trying to use it as a radar sensor for the interior only... doesnt work when i put my hand in my car which is supposed to detect movement it only detects the negative trigger from when i open the door which is when i connected the negative interior trigger to i would like to to if thats correct or if i need to return the microwave/radar sensor because it doesnt detect any movement in the car
i think i figured it out... i have to put a diode on both the door trigger and the radar sensor a 1 amp diode... and hook up to the negative door trigger... i'll let u know tomorrow if it works
black - ground
red- 12 volt power
blue- interior trigger i isolated w/ 2 diodes one for the door trigger and the other for this radar sensor
green- exterior ,i didnt use but i taped up the end of the wire w/ electrical tape
now the exterior light blinks when i move my hand around it but when i hook it up as the only trigger the alarm doesnt go off
it has 2 leds one green exterior and one red for interior
i tried hooking up each one one at a time but still no out put my alarm
only blinks green light if i move my hand across it
it should not get connected to your door pin wiring at all.... you can multiplex both zones and hook it up to a secondary negative input on your alarm, like the trunk or hood input whichever is unused... but you dont parallel it onto your door trigger wire as a rule....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
i dont have an extra input... but i did put 1 amp diodes w/ the door trigger and the radar sensor to isolate it... i only have an ouput for the trunk and for the window but they are outputs... so i ordered another radar sensor by bulldog but i have only a single stage shock sensor... so hopefully the bulldog works thanks anyore suggestions???
