Zapped 771xv
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74390
Printed Date: June 11, 2024 at 4:06 AM
Topic: Zapped 771xv
Posted By: raven509
Subject: Zapped 771xv
Date Posted: March 13, 2006 at 8:19 AM
I had a 771xv professionally installed in my 2000 F250. I purchased a second transmitter which worked fine for the past year. I recently got a 791xv professionally installed in my car with a second remote. I wanted to take one of each type of remote and have it for each vehicle. I zapped the 771xv with a bitwriter to remove the remotes from memory and went to install one of the original remotes as per the installation instructions. I opened the door, turned the key to the on position, and then pressed the valet/program button to select channel one. Nothing happened. The LED did not flash, no siren output. I pressed the valet/program button a second time and held, and pressed the lock button on the remote. Again, nothing happened the LED did not flash, no siren output. Any suggests on what I'm doing wrong, and how to program the remote to the 771xv? Also, will I have the same problem programming the 791xv? I did not do anything with that one since I could not get the 771xv to work.
Posted By: jonchos
Date Posted: March 13, 2006 at 9:16 AM
The learn routine can be locked. The only way to unlock it is with the bitwriter. You are supposed to get a long chirp when trying to program it, if the learn routine is locked. This might be another angle to look at the problem. Also, is your valet switch connected?
Posted By: raven509
Date Posted: March 13, 2006 at 9:23 AM
It is not locked. When it is Zapped, it would also put it at the factory default settings. That would also unlock it, if it was. I did verify that it is not currently unlocked. The valet switch does work. It allows me to put the alarm in valet mode, and take it back out. It is currently not in valet mode. I believe that it is not suppose to allow you to program the larm in valet mode. I did try both ways though.
Posted By: raven509
Date Posted: March 13, 2006 at 9:24 AM
Correction: It is not locked. When it is Zapped, it would also put it at the factory default settings. That would also unlock it, if it was. I did verify that it is not currently locked. The valet switch does work. It allows me to put the alarm in valet mode, and take it back out. It is currently not in valet mode. I believe that it is not suppose to allow you to program the larm in valet mode. I did try both ways though.
Posted By: jonchos
Date Posted: March 13, 2006 at 9:32 AM
try it opening both doors. instead of just one. Disconect the power to the alarm for a few min and then try it again. Just some more options.
Posted By: mobilecustoms
Date Posted: March 13, 2006 at 10:03 AM
for channel 1 you open door, turn ign on and press release valet button, then press and hold. you should get a chirp, while still holding the valet press the lock on the remote. turn ign off.
Date Posted: March 13, 2006 at 10:04 AM
also i dont think a 771 remote will work with a 791. and visa versa.
Posted By: raven509
Date Posted: March 13, 2006 at 10:39 AM
I tried disconnecting the batteries (it's on a diesel truck) for 10 minutes. It is doing the same thing. No lights, or chirps. I tried both doors open, right door only, left door only and even both doors closed. All have the same results. As far as the "locked" transmitter, I went back and purposely locked it and tried it that way, then unlocked it and tried again. It still has no lights/chirps after pressing the valet button. I read in one of the forums that the remotes would work on each, but at this point, I am just trying to get it to work as it did before I started. Luckily, I did not do anything with the 791xv alarm.
Date Posted: March 14, 2006 at 8:00 PM
does anybody know for sure that a 771 remote will work with a 791 system?
Posted By: cntrylvr79
Date Posted: March 14, 2006 at 8:22 PM
No the lcd remote from a 771 can not be used on a 791 and vice versa. I've tried it many times in the past because of customers. The only way to change the remotes is to change the antenna as well. The down side is you still can't mix and match remotes.
------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Date Posted: March 14, 2006 at 9:30 PM
ok, then can a regular 4 button remote viper like from a 160 be used with a 771 remote and its antenna?
Date Posted: March 14, 2006 at 11:46 PM
Nope have to use the led remote. TRied the 4 button ones too
Posted By: kgerry
Date Posted: March 15, 2006 at 12:12 PM
if it is an LED remote then yes you can learn any compatible 4 button 1 way remote to it... if it is the LCD remote (791, etc) then the only compatible 1-way remote is the 472 series remote
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: March 15, 2006 at 3:03 PM
can a led remote work with an hx antenna?
Posted By: kgerry
Date Posted: March 16, 2006 at 12:55 PM
nope, dont believe so... i could be proven wrong tho... i know the the XHF antenna for the LED units and the XHF antenna for the Valet 554 although looking identical are in fact different frequencies and dont work.... and HX is their entry level antenna with no return comm lead at all.....
Owner/Installer
Classic Car Audio
since 1979
Posted By: raven509
Date Posted: March 17, 2006 at 8:44 AM
Thank you all for your adivce. I still have not figured out how to get the remotes programed in after the ZAP, but I do appreciate all of your advice.
