Tahoe, Crimestopper
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74834
Printed Date: February 07, 2026 at 5:26 AM
Topic: Tahoe, Crimestopper
Posted By: masonsdad
Subject: Tahoe, Crimestopper
Date Posted: March 21, 2006 at 12:26 AM
I will preface this by saying I am a novice when it comes to GM installs, so please don't laugh too loud.
2004 Chevy Tahoe, Crimestopper RS-999-TW1, GM-SL
PROBLEM  As wired, the RS will perform tach-finder mode (parking lights flash) and will change to tach mode by pressing the brake pedal, but the remotes do not work.  I have tried to program them, but the RS will not enter the code learning mode (parking lights do not flash).  The remotes act as if the antenna is not connected.  The RS never attempts to start the vehicle.
On the GM-SL I have connected the following:
Connector 1:
Brown ------------------White from 7 pin connector on RS-999-TW1
Blue----------------------Yellow/Black @ pin 3
Purple-------------------Pin 2 on diagnostic plug
White--------------------Blue on door lock connector
Cyan---------------------Green on door lock connector
Grey/Black------------Grey/black @BCM Black plug pin "E"(ground when dome light off)
BLACK/ White-----------Not used
Pink----------------------Pink @ Steering column
Red----------------------- 12 V +
Black--------------------Chassis Ground
Connector 2:
White------------Pink @ pin 7 on RS
As far as the RS-999-TW1 connections, the wires I have not used are:
Brown @pin 4
Green @Pin 5
ORANGE / Black @pin 9
Orange @pin 10
Red @ door lock plug
Any help would be greatly appreciated.
Richard
Date Posted: March 21, 2006 at 12:51 AM
Also, I can ground the Green wire (Start activation input) from the rs and it will start and work perfectly.  It acts as if the antenna or the remotes are not working.  Any Ideas?
Posted By: xtremej
Date Posted: March 21, 2006 at 2:23 PM
It will or won't enter programming mode. If it will try to re-learn the remotes to the brain. I am a crimetsopper dealer and weve had a couple that weren't lprogrammed to the brain they were shipped with. Hope this helps.
Date Posted: March 21, 2006 at 2:58 PM
It will not enter program/learn mode, but does everything else.  The remotes don't work, but grounding the start activation input starts the vehicle.   I took it out and tried to do it on the bench, and it still doesn't enter remote learning mode.  Could I have a bad RS, or is there something else I should try?
Posted By: xtremej
Date Posted: March 21, 2006 at 3:05 PM
did you install a hood pin? If not ground out hood pin wire I believe is gray. Then try programming.
Date Posted: March 21, 2006 at 3:07 PM
yeah, it's grounded with a hood pin.
Posted By: xtremej
Date Posted: March 21, 2006 at 3:24 PM
You may have a bad brain, it happens. You don't happen to have another one to test the theory its bad do ya?  You might try crimestoppers tech line they may have an idea, try to talk Larry if do call he's pretty sharp.
Date Posted: March 21, 2006 at 3:26 PM
No, I don't have another, I'm strictly a DIY'er.  I talked to Mark @Crimestopper and he didn't know either.
Posted By: xtremej
Date Posted: March 21, 2006 at 3:31 PM
I believe I spoke with him once, he read the install guide to meposted_image. Maybe someone on the 12volt has Larry's extension I can't remember if its 109 or not? Anybody know???
Date Posted: March 21, 2006 at 3:34 PM
I sent Larry an e-mail, but haven't been able to get him on the phone.
Posted By: xtremej
Date Posted: March 21, 2006 at 3:39 PM
Hope it all works out for ya!
Date Posted: March 21, 2006 at 3:46 PM
Talked to Mark again... He wants me to send it in.  I should know by now to expect my luck to give me a defective starter.  Thanks for your help.
