05 Buick Rendezvous remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74863
Printed Date: May 29, 2024 at 12:29 AM
Topic: 05 Buick Rendezvous remote start
Posted By: Vyse
Subject: 05 Buick Rendezvous remote start
Date Posted: March 21, 2006 at 3:53 PM
I put an Avital 4000 on a '05 Rendezvous a couple weeks ago. The customer called back today saying that his navigation wasn't working. Any ideas? The remote start shouldn't have anything to do with that, right? I didn't disconnect the battery or the head unit or any other factory system, so I'm stumped. Any help would be greatly appreciated.
Posted By: Velocity Motors
Date Posted: March 21, 2006 at 4:24 PM
Does the NAV not engage or just not working in the sense that the NAV is giving wrong information ?
------------- Jeff
Posted By: Vyse
Date Posted: March 21, 2006 at 7:27 PM
Not sure. A guy I work with took the call and told me about it when I stopped in to get a few tools. I'll ask about it again when I go to work thursday. He made it sound like the nav system didn't work at all. I know that the sat radio and regular audio functions worked when the car left the bay, but I didn't sit and test the nav system. But, I can't think of what I could've done with the remote start/keyless that would affect the nav system.
Posted By: Vyse
Date Posted: March 24, 2006 at 5:14 PM
I looked at the Rendezvous today, and the nav was giving the wrong info. For some reason it thought it's position was about 250 miles off. I'm from southern Illinois and the nav system said I was in southwest missouri. Any ideas on what the problem is, more specifically, is there any way installing a remote start(Avital 4200) would affect this. I'm stumped.
Posted By: gus1
Date Posted: March 24, 2006 at 9:06 PM
Try unplugging the Avital's antenna and seeing if the Nav. gains it's bearings (used to be an issue on the odd GM's compasses that were in the mirrors).
Never know....
Gus
------------- Wherever I go, that is where I end up......
Posted By: Vyse
Date Posted: March 25, 2006 at 6:35 AM
Thanks, I'll give it a shot. At this point, I'll try anything.
Date Posted: March 25, 2006 at 8:04 AM
Remove the fuse for the Avital system as well to see if this helps.
------------- Jeff
Posted By: sparkie
Date Posted: March 25, 2006 at 8:09 AM
If the Nav system works, but shows an incorrect postion then the problem is most likely with the GPS antenna for the Nav system. As long as the vehicle tracks while moving, the GPS antenna probably needs replacing. Make sure that you haven't obstructed the antenna in any way or put any electronic module or relay close to it. Did you also power the brown wire in the ignition harness as a second accessory. This must be done on these vehicles.
------------- sparky
Posted By: Chris Luongo
Date Posted: March 25, 2006 at 10:26 AM
Is the brown, second-accessory wire being powered with remote start? If not, try doing that.
Posted By: Vyse
Date Posted: March 26, 2006 at 10:15 PM
To my memory, I did connect this wire. When using the remote start, everything powers on(heat, radio, etc..) like normal. Would this affect the unit when started with the key? Where exactly is the GPS antenna on this vehicle? I placed the Avital antenna by the rear view as close to the headliner as I could.
Date Posted: March 27, 2006 at 7:33 AM
On most new GM vehicles, the radio will still come on with remote start, even if the brown radio wire has not been powered.
On most all GM cars, I don't power the brown, and I don't have a problem.
However, on the Rendezvous/Aztec, sometimes the Service Engine message will come up on the dashboard if the brown wire isn't powered, so now I always connect it when doing those cars.
But anyway, just because the radio is on doesn't mean the brown wire isn't powered---it's worth checking out.
Posted By: Vyse
Date Posted: March 27, 2006 at 10:28 AM
But, when the vehicle is running, not remote started, everything will be powered normally. That's what the issue is. The nav wouldn't work when started with the key either. It couldn't get it's bearings. To my memory, I powered everything when I installed the Avital, but it was almost a month ago, and now the customer complains of nav problems.
Date Posted: March 28, 2006 at 6:26 AM
Ah, okay, sorry about that---I thought it was working okay when started with the key---I didn't read carefully enough.
Couldn't hurt to see what the owner's manual for the car has to say. There might be some way to reprogram or recalibrate something.
But, as others have said, if it does the same thing even with the key, it most likely isn't your fault. Hopefully it's still under warranty.
Posted By: Vyse
Date Posted: March 28, 2006 at 11:06 AM
I tried the owners manual, and there is a seperate manual for the nav system, which the customer didn't have, of course. I can't figure out what I could've done, and neither can any of the other installers at work. Thanks for all of the input as soon as I find out the reason I'll post it. Thanks.
Posted By: Vyse
Date Posted: March 28, 2006 at 5:26 PM
The problem has been solved. It turns out it was the Avital antenna. It took the Buick dealership two days to find it. I wish I had known the day the Rendezvous rolled in. I could have saved the store $140 and myself a headache. Well, live and learn and thanks to everyone who gave me advice.
