99 ford windstar, alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75145
Printed Date: May 08, 2026 at 9:01 AM
Topic: 99 ford windstar, alarm/remote start
Posted By: djlayz
Subject: 99 ford windstar, alarm/remote start
Date Posted: March 26, 2006 at 7:06 PM
im getting a 99 ford windstar on tuesday and i have my HU and alarm/command start (compustar) to put into this. what i wanted to know if i needed anything special (ie. bypass) to install it. if someone could let me know what i need that would be very helpful.
Posted By: xscash
Date Posted: March 26, 2006 at 7:33 PM
most likely has ford pats system. make sure the deaper/seller is giving you atleast 2 keys. plenty of bypass options, but you must have 2 keys. XS ------------- expandable sound
south of boston
Posted By: dea,can
Date Posted: March 27, 2006 at 3:25 AM
555P Ford Transponder Kit
Bypass the OEM PATS transponder anti-theft systems found on many new Ford, Lincoln, Mazda and Mercury cars and trucks, Only bypasses factory anti-theft systems during remote starting, keeping the factory system intact at all other times. Simple ten-wire connection for easy installation with auto-learning.
This Interface module is completely self-contained; no spare key is required or removing the steering shroud or ignition lock |
Made by Dei ------------- dragon
Posted By: dea,can
Date Posted: March 27, 2006 at 3:32 AM
RELAY 1 WIRING PARKING LIGHTS ON 99-UP WINDSTARS AND 2004 FREESTARS PIN CONNECTION 85 TO CHASSIS GROUND 86 TO (+) PARKING LIGHT OUTPUT FROM ALARM/REMOTE START SYSTEM 87 TO PIN 87 OF RELAY 2 87A TO DK.BLUE/WHITE WIRE – CAR SIDE 30 TO DK.BLUE/WHITE WIRE – HEADLIGHT SWITCH SIDE RELAY 2 PIN CONNECTION 85 TO CHASSIS GROUND 86 TO (+) PARKING LIGHT OUTPUT FROM ALARM/REMOTE START SYSTEM 87 TO BLACK/ LT.GREEN WIRE AT HEADLIGHT SWITCH 87A TO TAN/WHITE WIRE AT HEADLIGHT SWITCH – CAR SIDE 30 TO TAN/WHITE WIRE AT HEADLIGHT SWITCH – HEADLIGHT SWITCH SIDE
Posted By: Velocity Motors
Date Posted: March 27, 2006 at 11:18 AM
The 1999 Ford Windstar only requires one active PATS key to program a PKF1 keyless bypass module. The parking lights as stated need to be interfaced properly with & the stereo requires Ford keys to remove the OEM deck from the dash. You will need a dash kit and also will require a wire harness.
------------- Jeff
Posted By: djlayz
Date Posted: March 27, 2006 at 12:02 PM
why do you need the key to remove the deck?
Posted By: kgerry
Date Posted: March 27, 2006 at 12:04 PM
not the car key... Radio removal "keys".... (i usually call them "tools")
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: kohara73
Date Posted: March 27, 2006 at 7:09 PM
Posted By: djlayz
Date Posted: March 29, 2006 at 10:12 AM
i was wondering if any one had a detailed diagram on how to connect a compustar 2W900FM-AS to a 99 windstar. i have the 555f bypass for it.
Posted By: kohara73
Date Posted: March 29, 2006 at 3:10 PM
Posted By: djlayz
Date Posted: April 01, 2006 at 3:06 AM
I didnt want to spend no 10$ on a tool that ive been told i can make out of a coat hanger. anyways i cant get the factory stereo out. i put the u shaped coathangers into the holes pulled outward and and pulled on the stereo and nothing. anyone have any advise?
Posted By: mobilecustoms
Date Posted: April 01, 2006 at 6:47 AM
for the windstar it is a little hard to get the radio out. You need the tools they are worth it for this van. You need something with sturdiness to get the radio out. Apply pressure outwards of the radio and pull. Keep trying it will take time to get it out. There is no other way.
Date Posted: April 01, 2006 at 8:22 AM
If you have a pick set use it to insert into each of the holes. If you do not have a pick set then an Allan key set will do the same.
------------- Jeff
Posted By: Scott35
Date Posted: April 01, 2006 at 11:30 AM
Walmart has them for approx $4or5.
------------- Tacomacrew
Posted By: djlayz
Date Posted: April 01, 2006 at 8:02 PM
i hooked up my stereo today and its not working. there was a fuse that was broken but i replaced it and nothing. so i dunno im goin to look some more into it tommorow. also i hooked my alarm/starter and i had some problems 1) one of the relays the manual said its for 2nd ign, 2nd str or 2nd acc. and theres 2 wires comein from the relay a purple and a blue and i have no idea what there for. 2) i dont know were the tach wire is suppose to go. i have no idea where the coil is. 3) i figured that without these hooked up it should still work. i followed the instuctions on how to set up the remote and nothing.
Posted By: kohara73
Date Posted: April 02, 2006 at 8:48 AM
Your van has 2 acc. and 2 ign. wires. If your R/S does not have these outputs, you'll have to add a relay or two to power them. It sounds like your R/S has a wire that is programmable for starter, acc., or ign. You'll have to find out how to set it in the manual. The coil is on top of the motor between the intake manifold and the firewall. Bit of a pain to get at, but it is possible. I've always used the pink/white wire there with no trouble. The R/S would not work when half way installed because you haven't programmed tach and it sounds like you may be missing an ignition and accessory wire. ------------- Keith
Date Posted: April 02, 2006 at 8:57 AM
go to the odd fuel injector wire they are in the front of the engine- very easy to get to forget the coil.
Posted By: dea,can
Date Posted: April 03, 2006 at 4:07 AM
wiring 1994-2003 windstars with some pics just have to download its safe. https://s26.yousendit.com/d.aspx?id=2CSMOAQFFU01F3RTRYZC80TFPT ------------- dragon
Posted By: djlayz
Date Posted: April 03, 2006 at 3:12 PM
i still cant get it to work. theres 2 lt GREEN/ purple wires and 2 red wires on the ignition harness and there is also no black for 2nd accesory. and i still cant find the tach wire. if anyone one knows what the purple and blue wires coming of the 2nd relay on my compustar A/S can you please tell what they are for.
Posted By: djlayz
Date Posted: April 03, 2006 at 3:15 PM
also would i hae to hook the factory alarm disarm up. and if so to what wire on my module.
Posted By: djlayz
Date Posted: April 03, 2006 at 11:38 PM
https://s40.yousendit.com/d.aspx?id=2MEV2YLOPR2SG1PAZ1827C549O https://s40.yousendit.com/d.aspx?id=3S6647GDHP1IQ09O0XHIFQM7AT here are 2 pics if anyone can help me out the first is the wiring diagram for my R/S and the second is how the wires are connected to relays and then where they go into the vechile. there are 3 wires that i put ? on and they are what i think may be my problem. so if anyone can help me i would be very grateful
Posted By: dea,can
Date Posted: April 04, 2006 at 3:26 AM
Just to too www. bulldogsecurity.com it will give u pics and show how to remove the ignition switch and place the transponder ring around the switch.also there is a movie u can watch and under stand how to wire in your remote starter.it a basic movie it will give a understanding how its wired. https://www.bulldogsecurity.com/ ------------- dragon
Posted By: djlayz
Date Posted: April 05, 2006 at 10:11 AM
Yesterday i got the alarm part of my R/S working, most of it anyways. i couldnt figure the door trigger out put i think i got it now, im goin to try later. also i couldnt figure out the door locks, i have the DEI 451M and i am unsure of how to hook it up. also i still havent got the remote start hooked up yet, I still have no idea were a purple and blue wire comin from a relay go. im guessin one is for 2nd ign & 2nd acc, but i dont know which one is for which and there is no 2nd acc wire on the igniton harness (black). i have finally found the igniton coil but now im confused. my manual is saying if i have an automatic i am suppose to hook it up to the alternator. if anyon has any ideas on of this please let me know thanks. thanks for everyone's help so far.
Posted By: dea,can
Date Posted: April 06, 2006 at 1:32 AM
Set your jumper to 2nd ign.to power up your second ign, and for tach wire to coil wire
Posted By: djlayz
Date Posted: April 06, 2006 at 8:38 PM
i now have everything hooked up and its all working so far except the door locks. i have the dei 451m door lock module but ihave no idea how to hook it up i tried every way possible and just wont work for me. so if someone out there can help me out please. (99 windstar)
Posted By: swamprat323
Date Posted: April 06, 2006 at 8:49 PM
Power Lock lt blue/orange - 20 pin plug at FEM module Power Unlock lt GREEN/ YELLOW - 20 pin plug at FEM module
you shold not even need the 451M, you have negtive system
Posted By: djlayz
Date Posted: April 06, 2006 at 9:36 PM
so i just hook up the 2 wires from my module straight to the 2 wires?
Posted By: mo12v
Date Posted: April 06, 2006 at 9:47 PM
Usually, but sometimes you will need Relays for Stronger GROUND Pulse Try it ------------- MO
Posted By: djsnovas
Date Posted: April 07, 2006 at 8:17 PM
1- for the power door locks you dont really need the dei 451m you can use 2 relays instead 2-the second relay of connector #1 look at connector #2 pins 3(green 2nd ignition) 4(WHITE/ black 2nd accessory) 5(RED / black 2nd starter) now for example if you hookup the green(pin #3) to the purple(small wire) of the 2nd relay from connector #1 then the blue(big wire) will power a 2nd ignition 3- for the tach there is a triple coil pack on the drivers side of engine and you can use the pink/white, RED / lt.blue or the blue/lt.green off the coil pack
Posted By: dea,can
Date Posted: April 08, 2006 at 11:57 AM
for your door locks its a -neg output from your remote starter just hook the wires direct your lock type in the van is a -neg output also. The COIL PACK is located on the DRIVERS SIDE of the ENGINE, for TCH use the PINK/WHITE, RED / LIGHT BLUE or BLUE/LIGHT GREEN ------------- dragon
Posted By: djlayz
Date Posted: April 09, 2006 at 11:23 PM
2 problems in my 99 windstar #1 - i hooked up the doortrigger with the diode (cathode away from the light) and the alarm input to the cathode side but every half hour my alarm goes off and the remote says doors are being opened. i really need to fix this its really annoying. #2 - i got my keyless entry to work but it only works for the sliding doors and trunk. even on thje door itself it only un/locks the back doors. anybody no how to get it s that all the doors un/lock with the remote
Posted By: mo12v
Date Posted: April 10, 2006 at 8:32 AM
Ford's F.E.M. And R.E.M. Will Drop A Low Signal Across The Dome Light And In Most Cases Cause A False Trigger. To Eliminate This, Connect One Side Of 10 k Ohm Resistor To The Door Trigger wire and Connect The Other Side Of The Resistor to 12 Volts. Alternate Wire: Use YELLOW/BLUE (-) At Under Dash Curtesy Lamp If Equipped. Does Not Require Pull Up Resistor. Use YELLOW (-) At Dimmer For Dome Light Supervision. Also, sounds like you do NOT have the correct wires for Door Locks or bad connection or you may need Relays for stronger GROUND Pulse ------------- MO
Posted By: djlayz
Date Posted: April 10, 2006 at 10:08 AM
i have it right have the door & trunk trigger input hooked up to the yellow/blue at the under dash with the diode and it goes off every 1/2 hour. i tried it with out the diode and the same thing. i havent tried a resistor yet but i found this on a different posting https://www.bulldogsecurity.com/New%20Wires/New%20Wires/Wires/images/windstardp.htm. i was wondering if this would work if i hooked it up to the yellow/blue instead of the ORANGE / white & BROWN / pink.. as for the door locks they are working according to the vechile wiring on here, it says that the drivers door lock & passenger door lock are different wires then the back. any suggestions on what i should do?
Posted By: djsnovas
Date Posted: April 10, 2006 at 10:29 AM
Posted By: djlayz
Date Posted: April 10, 2006 at 10:14 PM
i got the door trigger working now. thanks for all the help. but i still dont got the door locks to work for the front doors. can anyone help me out with this one. also i still uncertain about the tach wire. its really hard to get to the wires under the hood. i was wondering if theres a wire under the dash. and if so were. i see a pink/white wire comin from the fuse box is this the same wire?
Posted By: djsnovas
Date Posted: April 11, 2006 at 11:13 AM
its easy to find the tach look under the hood, locate the throtle cable now just behind it you will see big wire harness with gray on it now just to the left is your coil pack there is a four wire plug on the right side of the coil pack (to the left of the big wire harness your pink/white is there just unplug it and its easy to get at as per your front door locks i need some more info does your back doors work ? do your factory switchs work on the front ? did they work before you installed the alarm/starter if your fronts dont work at all then you might have a break in a factory wire.
Date Posted: April 11, 2006 at 12:01 PM
the lcoks are at the fem module under the dash . for tach go to an injector. its easy to get to at the front of the engine
Posted By: djlayz
Date Posted: April 11, 2006 at 12:08 PM
the lock & unlock buttons on the drivers and passenger door both unlock the back doors and the trunk. they dont lock / unlock the front doors. this is how they were before i installed the r/s
Posted By: djsnovas
Date Posted: April 11, 2006 at 7:41 PM
well i guess you'll have to get a wire diagram for the factory door locks so you can check the wires for breaks also check the factory relays maybe they are fried
Posted By: djlayz
Date Posted: April 12, 2006 at 12:29 PM
i think i figured out the problem with my door locks. i think the actuators are fried. so i ordered a set yesterday. i was wondering how hard is it to install aftermarket actuators in my windstar.
Posted By: djlayz
Date Posted: April 13, 2006 at 12:24 PM
https://www.the12volt.com/installbay/forum_posts.asp?tid=63938&KW=windstar does the procedure at the bottom of this post actually work. i would like to know because i only got 1 key with my van and i got the spare key made at ford but didnt get it programmed yet. so if anyone knows if this works please let me know cause this will save me lik 50$.
Posted By: djlayz
Date Posted: April 17, 2006 at 7:28 AM
last night my shock sensor kept going off every half an hour till i finally decided to turn it off. and i also noticed my rps goes off everyonce in a while, when nobody is around my car to knock on the window. does anybody know why these 2 things keep going off.
Posted By: djlayz
Date Posted: April 18, 2006 at 12:41 PM
well i turned the sensitivity on my shock sensor down to 2 and its not going off but my paging system went off a couple of times still. and there still is no one around to knock on the window. so one has to know whats up with this. it cant be 'cause i hooked it up wrong.
Posted By: djlayz
Date Posted: May 12, 2006 at 10:09 AM
ok i need to know if there is a way to set up my r/s without having the 2 keys. can anyone help me out please?
Posted By: Twelvoltz
Date Posted: May 12, 2006 at 12:23 PM
Chris' post will work, so long as you can get a key that can be cut and turn the ignition cylinder. Doing it this way would be the least expensive, but also would take away the functionality of the factory anti-theft system. You can go to the dealership and have them program a new key to the vehicle without the need for 2 original keys, but I have heard this is a very expensive option.
Hope this helps.
