94 grand cherokee prostart rs/alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75204
Printed Date: May 07, 2026 at 3:10 PM
Topic: 94 grand cherokee prostart rs/alarm
Posted By: rockyfarted
Subject: 94 grand cherokee prostart rs/alarm
Date Posted: March 27, 2006 at 5:35 PM
Ok problem here when I installed everything all went well,  Except that the doors are not protected by their trigger wire yellow(-) when i use the key to unlock while alarm active then alarm should trigger with dome light or door trigger correct it goes off with shock noprob. ??
Okay all other options installed work correctly, do i need to use diodes on each trigger wire under the column tan/whatever all 5 of them there or am I misiing something here??????  Should i have disabled the factory alarm ie....grounded it out?????  If someone can lend some info this way I be greatly appreciated of the help I'm stuck.
Posted By: xscash
Date Posted: March 27, 2006 at 7:33 PM
does your dome light come on when you open the door?
expandable sound
south of boston
Date Posted: March 27, 2006 at 7:56 PM
Yes the thanks for the post but yes the door and overhead and underdash and all lights come on but the alarm does not sound even if i open the door witht the key or does that disarm the alarm like the factory one does...  Still lost here.  And one other thing i had a problem with the factory alarm that would sound any it said the hatch was open when it actually wasnt but maybe the trigger was loose sometimes ... Dunno if that has anything to do with it but the factory one should be disabled right ...
Posted By: Velocity Motors
Date Posted: March 27, 2006 at 10:16 PM
Which Prostart are you installing. Some systems have both (-) and (+) door trigger inputs. Make sure you have it hooked up to the proper one.
Posted By: dea,can
Date Posted: March 28, 2006 at 1:14 AM
DOOR TRIGGER (-) YELLOW Harness In Driver’s Kick Panel
• Do not use courtesy light under dash for door trigger or dome light supervision
HOOD TRIGGER (-) BROWN / TAN Harness In Passenger’s Kick Panel
FACTORY ALARM ARM (+) PINK/ORANGE Harness In Passenger’s Kick Panel
FACTORY ALARM DISARM (-) PURPLE / YELLOW Harness In Driver’s Kick Panel
dragon
Date Posted: March 28, 2006 at 5:36 AM
The Model is CT-5000 3 in 1 Automatic trans going into 94 grand cherokee and neg door trigger output on the module and neg door trigger on the truck yellow (-) wire but alarm doesnt sound with
