info for mitsubishi montero
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75280
Printed Date: May 07, 2026 at 5:31 PM
Topic: info for mitsubishi montero
Posted By: pitoaudiovisual
Subject: info for mitsubishi montero
Date Posted: March 28, 2006 at 8:16 PM
can anyone tell me if there is a difference between 03 montero and 03 montero sport if so please give me the paper work for a montero sport I have for regular montero thanx in advance. Also is second accessory the same as second ignition.
Confidence is the key to any project!!
Posted By: Twelvoltz
Date Posted: March 28, 2006 at 8:31 PM
The Montero and Montero sport are different vehicles, the Montero is a larger truck. Here is a link to the diagram for an 03 sport.
Second accesory is not the same as second ignition. The accessory wire loses power when the starter is engaged the second ignition does not. Most systems have a programmable second ignition output that you can set to operate as an accessory. The 03 sport has 1 ignition and 2 accessories. Although you may not need the second accessory you can use the second ignition output from the system and reprogram it to operate as an accessory.
Date Posted: March 28, 2006 at 8:48 PM
sorry but the link didn't work can u send it again.  Thanx
Date Posted: March 28, 2006 at 9:14 PM
I just clicked it again and it worked, in both IE and Firefox. But you can just go to designtech-intl.com and click on Wiring Diagram. It is the same information that you would get with directwire, but limited to just keyless, remote start, security, and you have to click a different link for the bypass info.
