05 300 bypass Module? Second Remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76131
Printed Date: October 31, 2024 at 7:37 PM
Topic: 05 300 bypass Module? Second Remote
Posted By: amoll2
Subject: 05 300 bypass Module? Second Remote
Date Posted: April 12, 2006 at 2:48 PM
Installed on 300 chrsler, does anyone know which bypass module.  I have a pass4 from omega, will dis work???  Also anyone know how to wire the second start wire, which is the same as the ACC wire.  Must use two seperate resistors 180, 610 but how to connect all to one wire???  Any help will be appreciated.  Thanks..
Posted By: Twelvoltz
Date Posted: April 12, 2006 at 3:20 PM
Second starter/Accessory wire.. The pass4 is a key-in-a-box type transponder bypass, correct? If this is the case, then yes you could use it with a spare key.
Side note:
Does anyone know if this bypass eliminates the need for the double relay setup or does it just provide the second starter resistance? The manual is pretty vague on this point.
