791 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76155
Printed Date: May 17, 2024 at 10:04 AM
Topic: 791 remote start
Posted By: COVETTE03
Subject: 791 remote start
Date Posted: April 12, 2006 at 10:54 PM
Ok so what happened was i got everything hooked up on my 04 focus and everything worked. i went down to set the brain and everything to where they were hidden and I believe that the remote start module came unplugged from the brain with the fuses in them. I know that in the install guide it said not to have the fuses in unless you have it plugged into the brain when installed (connected to the 12v+ constant) Now my remote start will not function. I plugged the rs module back in checked the fuses and still get nothing from remote starting. Do I need to replace the remote start module? Can anyone help. I have tried relearning the tach and everything. Nothing comes up still.
Posted By: spookiestylez
Date Posted: April 13, 2006 at 9:30 AM
I assume everything else works on the alarm..I would check ALL my connections. When you try to remote start do you hear the relays kicking over or is it not doing anything, could be a bad ground, neutral saftey switch, or bypass module(if one was needed)....good luck,LMK how it goes. sS
Posted By: MrSuperStar
Date Posted: April 13, 2006 at 12:05 PM
what exactly do you hear (or not hear) while remote starting. I've come across only two issues with this car
1) the positioning of the bypass module is extremly sensitive. I had to reposition the thing like 6 times before it finally worked consistently
2) depending on where you get the tach signal, the car may start and shut off after about 1 min or less. If I recall the tach signal changes during warmup causing the rs to cut off. The fix was to just get the signal elsewhere, but I forget.
Good luck, more details will help.
Posted By: cntrylvr79
Date Posted: April 13, 2006 at 7:09 PM
Fords you have to get the tach wire at an injector for the r/s to continue to run properly. As to the not working part, do the parking lights flash when you try to remote start the car? If not check the hood pin, neutral saftey, and the brake wire. The hoodpin should not be getting ground and the brake wire should not be showing +12v. The neutral safety should be getting a ground. It the parking lights are flashing and the starter isn't engaging make sure the ribbon harness is completely connected to both the brain and the relay pack. if it is, disconnect the power from your bypass module, slide a key into the ignition but don't turn it. Try remote starting now. If it starts and runns properly then there's something wrong with the bypass. Let us know how it works out for ya. ------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Posted By: dave454
Date Posted: April 14, 2006 at 3:07 AM
Can you go a bit deeper on this, does it need to be flat, or what is the correct position for this module?
Date Posted: April 14, 2006 at 7:27 AM
I used the bypass with the capsule, 555s I belive. There is no one place I can tell you. just position till it works, ziptie the hell out of it, and test it 12 times before you put it all back together.
If you unsuccessfully try to start the car too many times, then the car is disabled for a few minutes till you can do it again.
Date Posted: April 17, 2006 at 7:22 PM
Alright thanks everyone for posting. I got it to remote start but I can't get it to remote start with the 555s. I put a new 555s in it caz the old one had broke wires. whenever I program the 555s it works once and thats it. If i move it or leave it in the same place on the ring it still won't work. I tried to reprogram the 555s and then it will work only once again. When I put the key in the ignition it works just perfectly but the 555s it seems like it's forgettin the codes because the security light will blink when I try to remote start. So I was just wondering how the HELL do i fix this. Should I just forget the 555s and go with the 555U/556U or what? is the 555u/556U easier to install with let sensitivity? Anyone got any suggestions on programing the 555S?
Date Posted: April 17, 2006 at 8:00 PM
Like I said, you will have to position the capsule lots of different ways before you get it right. I don't think you'll have any luck with the 556U.
The capsule has to mount close to the ring or close to the wires that lead to the ring. And when you do get it, make sure that capsule stays there. Otherwise by the time you put it all back together it wont work again.
