Does anyone have this diagram for 1997 Dodge ram 318 quad cab. I'm trying to install a remote starter. Any help would be extremely appreciated.
Garey S.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red or pink/black |+ |ignition harness |
| STARTER|blue / YELLOW |+ |ignition harness |
| IGNITION|dk. blue |+ |ignition harness |
| SECOND IGNITION| | | |
| ACCESSORY|blk/orn & blk/wht |+ |ignition harness |
| POWER LOCK|ORANGE / purple |*2 |lt blue plug in driver kick |
| POWER UNLOCK|pink/purple |*2 |lt blue plug in driver kick |
| PARKING LIGHTS +|BLACK / YELLOW | |yellow plug in driver kick |
| HEADLIGHTS|lt. green |+ |steering column |
| DOOR TRIGGER|yellow |- |yellow plug in driver kick |
| TRUNK/HATCH PIN| | | |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|gry/blk, blk/gry *1 | |coil pass. side engine |
| BRAKE WIRE|WHITE/ brown |+ |at brake pedal switch |
| HORN TRIGGER|dk. GREEN/ red *3 |+ |relay at fuse box |
| WIPERS|RED / yellow |+ |wiper switch |
| LF WINDOW UP/DN|lt. blue - white |A |at drivers door switch |
| RF WINDOW UP/DN|brn/wht - pur/wht |A |at drivers door switch |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
Notes:
*1 Also located as gray/blue at large plug through firewall on driver's side at highest point of firewall, also gray/blue at cluster. Diesel tach wire is gray/black and diesel wait to start wire is ORANGE / black (-) 'see direct fax document #1090'. Both wires are located at the PCM on the passenger side firewall or can also be located in the main harness that runs along the firewall. *2 Positive trigger on models with factory keyless entry, and 5 wire on all other models. *3 Also BLACK/ red (-) at column or relay.
