any one have information on remote start /car alarm wiring diagram for this vechile?
DUALLYIT
Constant 12 volts | WHITE OR WHITE/ RED | IGNITION SWITCH HARNESS |
Ignition 12 volts | BLACK/ RED | IGNITION SWITCH HARNESS |
Starter | GREEN/ BLACK (M/TRANS) | IGNITION SWITCH HARNESS * |
Dome Light | WHITE/ BLUE (-) | DRIVER KICK PANEL |
Trunk Pin Switch | NONE | |
Parking Lamp | GREEN (+) | DRIVER KICK PANEL |
Power Lock | WHITE/ GREEN | DRIVER KICK PANEL ** |
Power Unlock | RED / YELLOW | DRIVER KICK PANEL |
* Starter Wire Is BLACK/ WHITE In Vehicles With Auto/Trans.
** Child Safety Wire Is RED / BLUE. Child Safety Door Lock Circuit
Accessories |
Window Up | D\ LIGHT GREEN P\ RED / BLACK AT MAIN SWITCH | |
Window Down | R/ BLUE / YELLOW S/ RED / WHITE * | |
Ign Key Warn | PINK/BLACK (-) | 2 PIN CONN AT STEERING COLUMN HARNESS |
Trunk Release | NONE | |
OEM Horn | GREEN/ RED (-) | STEERING COLUMN HARNESS |
Headlights | GREEN/ YELLOW (-) | AT HEADLIGHT SWITCH |
OEM Alarm Arm | WHITE/ GREEN (-) | |
OEM Alarm Disarm | BLUE/RED (-) | DRIVER KICK PANEL |
* Access Cab: Rear Window GREEN/ BLACK (UP), RED / BLUE (DOWN) At Switch
Reversal Rest At Ground Window Circuit
OEM Hood Pin-None OEM Horn- BLACK At Horn Behind Grill, In Front Of Radiator
Remote Start |
Tach Signal | BLUE/WHITE | AT ECM BEHIND GLOVE BOX (8 CYL) * |
Ignition #2 | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #3 | NONE | |
Accessory | BLUE/RED | IGNITION SWITCH HARNESS |
Neutral Safety | NON GROUNDING TYPE | |
Brake Light | GREEN / WHITE (+) | AT SWITCH ABOVE PEDAL OR IN DKP |
Reverse Light | RED / BLACK (+) | DRIVER KICK PANEL @ BACK UP RELAY |
Rear Window Defrost | NONE | |
*Can Also Be Found At Back Of Instrument Cluster. 6 Cylinder TACH Wire Is BLACK Located In 12 Pin Conn At Rear of Driver Junction Block Or One Of The Coil Wires At Igniter;( BLU/BLK, RED / BLK, LT GRN) Behind Air Filter Box.
MO
