I need a wiring diagram for this car. Thank you in advance!
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white - WHITE/ red |+ |ignition harness |
| STARTER|red |+ |ignition harness |
| IGNITION|BLACK / YELLOW |+ |ignition harness |
| SECOND IGNITION|BLACK/ red *1 |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| POWER LOCK|dk. blue/white *3 |- |org plug bottom of fusebox |
| POWER UNLOCK|dk. blue *3 |- |org plug bottom of fusebox |
| LOCK MOTOR|blue/red | |org plug bottom of fusebox |
| UNLOCK MOTOR|blue | |org plug bottom of fusebox |
| DISARM DEFEAT|blue/black | |org plug bottom of fusebox |
| PARKING LIGHTS +|green | |bottom of fusebox *4 |
| PARKING LIGHTS -|green | |steering column |
| HEADLIGHTS|RED / yellow |- |steering column |
| DOOR TRIGGER|RED / white |- |top of fuse box *5 |
| TRUNK/HATCH PIN|RED / yellow |- |light or sw. in trunk |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blu/blk (key sense) |- |ignition harness |
| TACHOMETER|black or gray *2 | |*2 |
| BRAKE WIRE|GREEN / WHITE |+ |bottom of fusebox *4 |
| HORN TRIGGER|GREEN/ black |- |steering column |
| WIPERS| | | |
| LF WINDOW UP/DN|green - red |A |drivers door switch |
| RF WINDOW UP/DN|grn/wht - RED / blu |A |drivers kick panel |
| LR WINDOW UP/DN|grn/yel - RED / yel |A |drivers kick panel |
| RR WINDOW UP/DN|grn/blk - RED / blk |A |drivers kick panel |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. *1 There are two BLACK/ red wires going to the same pin at the plug. use either one. *2 On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor. On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the strut tower. The module says Denso on it. *3 The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself. *4 In a white connector just below the fuses with the wires exiting out toward you. *5 Located in a seven pin plug on the top right side of the fuse box.
