Door lock/unlock with ignition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79951
Printed Date: June 09, 2024 at 4:48 PM
Topic: Door lock/unlock with ignition
Posted By: Red97LT1
Subject: Door lock/unlock with ignition
Date Posted: July 05, 2006 at 3:50 PM
I was wondering if I could wire a relay to get my doors to lock/unlock with the ignition. I want to do this on a 97 Chevy Camaro Z28.
Posted By: captainzab
Date Posted: July 05, 2006 at 4:09 PM
Hey, too lazy to read read through the post, but this guy was doing the same thing, so read his and post question about it here if you cant figure it out
https://www.the12volt.com/installbay/forum_posts.asp?tid=1624&KW=ignition+lock
Posted By: dualsport
Date Posted: July 07, 2006 at 5:19 PM
Could try something like this if you want to DIY:
Have to be careful putting it together if you try it though, wouldn't be good if it latched your door lock
signal on continuous if something goes wrong-
Posted By: bmwpwner
Date Posted: July 09, 2006 at 5:59 PM
check your manual for PROGRAMMABLE FEATURES first. most of the alarms/keyless unit i have done over the years have had this feature. i personally don't like it and since DEI comes defaulted with ignition lock/unlock ON i just program them to OFF and done. good luck and hope this helps.
------------- "I cannot teach anybody anything, I can only make them think."
-Socrates-
Posted By: cadillac_coupe
Date Posted: July 09, 2006 at 11:09 PM
You know that Cadillac has this feature on some of their models; only difference is that they lock when their is someone seated on the drivers seat, all other doors closed and seatbelt on, then moving the gear selector to D and unlock when returned to P. I believe you an find them in their Fleetwood Brougham. Since in these models this option was dealer installed. Maybe you can find one and take the entire system, wiring, relays etc and use it for your application. If you can do this, I can help with the wiring though it'll vary to yours but maybe it'll work. It won't hurt to try it out.
------------- cadillac_coupe
Posted By: bmwpwner
Date Posted: July 09, 2006 at 11:30 PM
i would hate to try and take something like that out of a caddy and put it into a camaro personally. it can be done but man that is the long way around the problem. i would first check and make sure that the alarm doesn't have the feature for ignition lock/unlock just to make sure you can't just program the existing alarm to accomplish the desired result. then if the alarm doesn't have that feature then you can move into a relay setup to lock/unlock on ignition. again, i personally don't care for this feature and btw i see alot of GM vehicles with worn out factory actuators so when you enable this feature will eventually have to replace those crappy GM lock motors. good luck and hope this helps. ------------- "I cannot teach anybody anything, I can only make them think."
-Socrates-
Posted By: dakkh
Date Posted: July 10, 2006 at 10:34 PM
I got a Black Widow X-5 car alarm, its got a 2 way fm lcd remote and i bought this thing for only 60 bucks from the clearance bin at my local stereo shop... all i got to say is the alarm has this feature you are looking for built into it and also black widow car alarms are great because "THIEVES HATE THEM LIKE POISION" ciao ------------- DKH
Posted By: wentworth007
Date Posted: July 12, 2006 at 10:28 PM
dude buy a DEI that cheap crap will only give you headaches and problems you will spend more time fixing the thing and troubleshouting then anything.
