Command Start CS-480I Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80403
Printed Date: May 19, 2024 at 3:14 AM
Topic: Command Start CS-480I Problems
Posted By: quiltyw
Subject: Command Start CS-480I Problems
Date Posted: July 17, 2006 at 2:07 PM
Hey Everybody,
I bought my girl friend this starter for christmas last year and I am trying to install it, I work at Bestbuy so the installer there gave me all the info on how to install it but for some reason I can't get it to start.
Here is how I have it wired:
Honda Civic 92LX Starter
12 V - white Red - Fused wire
Ignition - Black / Yellow Yellow
Accessory - Yellow Orange
Starter - Black / White Purple
Not Connected Green - Fifth Relay
Brake - Green / White Yellow - Fused wire
Parking Lights - Red / Black Orange
Tach - Blue @ Driverside Purple
Strut Tower from
distributor
Ground - Screw on metal Black
at dash
Hood Pin - Grey
Can anyone please verify my wiring and tell me why it's not working. It doesn't even try to fire the engine and I get a blinking of the parking lights 3 times. When I check the diagnostic codes I found that I have a code 5 - New transmitter programmed, - Tach programmed.
What does this all mean??
Any help would be greatly appreciated!
Wally
Posted By: 12voltmaster
Date Posted: July 17, 2006 at 4:32 PM
quiltyw wrote:
Hey Everybody,
Strut Tower from
distributor
at dash
Hood Pin - Grey
Wally
Vehicule is a manual or automatic ???
Posted By: quiltyw
Date Posted: July 18, 2006 at 6:28 AM
It's an automatic!
Wally
Date Posted: July 18, 2006 at 2:22 PM
quiltyw wrote:
It's an automatic!
Wally
If you unplug you HOOD PIN. The vehicule start ??
You TACH is learn by the remote-starter ??
Posted By: ck auto
Date Posted: July 19, 2006 at 1:23 PM
double check your park light and brake wiring it looks like you got them reversed
------------- good luck
kirk
Posted By: quiltyw
Date Posted: July 24, 2006 at 10:25 PM
If I un plug the hood pin no it will not start.
The parking lights and the brake lights are all working as they should. I believe that the lights are all hooked up correctly.
I think it has somthing to do with the programing of the tach and the tach signal. I have tried serveral time to get it to learn the tach programing but I don't think that it is actually working. I took a DMM to test it and the results were as follows:
Blue tach - negative terminal of DMM
Chassy Ground - positive terminal of DMM
Key in on position Max reading 15.0 mV
Running Idle Min reading 75.0 mV
Blue tach - positive terminal of DMM
Chassy Ground - negative terminal of DMM
Running Idle Min reading 00.8 mV
What does all this mean??
Wally
