shorted brown siren wire from module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80969
Printed Date: May 23, 2024 at 1:40 PM
Topic: shorted brown siren wire from module
Posted By: armani1318
Subject: shorted brown siren wire from module
Date Posted: July 30, 2006 at 3:05 PM
I shorted my brown output wire from my alarm module and now I don't have any siren noise at all. I was wondering if I can use another wire to have my siren back. i already tried my white parking light output wire by using a relay and a diode but there was a big down to doing this. When ever I had my lights on my siren would be activated, that means I was gonna be going down the road at night with my siren on at all times. Is there anythihng I can do or buy to get my siren back?
Posted By: captainzab
Date Posted: July 30, 2006 at 3:52 PM
Try taking out the brain completely and letting it chill over night. Cuz once i thought i fried my domelight output because i couldnt lock or unlock and the alarm was all messed up. I took out the brain and a week later decided to put it back in and it worked. I didnt know what happened but the problem went away by itself.
Posted By: glantern83
Date Posted: July 30, 2006 at 8:04 PM
to preent the siren from goin of when your lihts are in use put use another reay on a witched sorce so that when you turn the car on it brakes the connection..... Or if you have a seprate horn honk wire use that an a relay to get use of our siren back....
-KITT
Posted By: ringojam
Date Posted: July 30, 2006 at 8:33 PM
Chech the curcuit board on the alarm and see if there is a damaged band or diode. And try and repeair the damage or replace the damaged curcuit if tou can,good luck.
------------- Jamaica home of the worlds fastest man.
Posted By: MrSuperStar
Date Posted: July 31, 2006 at 8:41 AM
the parking light connection would work if you used the diode correctly.
The siren wire must be spliced into the white wire BEFORE the connection to your parking light.
The diode then must be placed in BETWEEN the two connections.
If you are using negative trigger then the stripe side of the diode must face the siren & alarm.
If using positive trigger the stripe side must face the parking light wire.
Hope that helps
------------- "My Lifestyle Determines My Deathstyle"
