1996 Dodge Ram 1500 alarm wiring problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80978
Printed Date: March 26, 2026 at 8:25 AM
Topic: 1996 Dodge Ram 1500 alarm wiring problems
Posted By: krissyysu
Subject: 1996 Dodge Ram 1500 alarm wiring problems
Date Posted: July 30, 2006 at 7:40 PM
Ok I bought an alarm for my husband's 1996 dodge ram 1500 pickup and I started to wire it. Unfortunately the instructions are extremely vague and I screwed something up... I now have a dead battery and fried a wire and also the door lock and unlock using the alarm did not work... This is what I wired from the alarm to the truck. If anyone can help me figure out what I did wrong I would greatly appreciate it. The alarm is a model hs-100 that I bought on ebay.
From the alarm                      color wire in alarm                     to the truck                      color wire in truck
10 wire harness
first wire                                               yellow                       yellow wire in relay (included w/alarm)     says this is for IGN.CYT.CJT
second wire                                         black                               ground                                       black           says this is for 12v storage battery (-)
third wire                                               brown                               headlights                                 lightgreen   says this is for direction light
fourth wire                                             pink                                  speaker for alarm                                        says this is for electronic speaker
fifth wire                                                 red                                      12v constant                                 red         says this is for 12v storage battery (+)
sixth wire                                               brown                                  headlights                      same as other  says this is for direction light
seventh wire                                         green                                    not used (trunk wire)
eighth wire                                            orange                               brake                                          white         says this is for foot brake switch
ninth wire                                             white                                     ignition2                              BLACK/ white    says this is for Key on (ACC) position
tenth wire                                                 blue                                    unlock door                     pink/purple      says this is for negative trigger door side switch
From the included relay                   color from relay                        to truck                         color in truck
yellow to main alarm box                      yellow                        yellow first wire in alarm 10 harness
no                                                               green                                 ignition 1                              dark blue
nc        white                                  ignition 1                               dark blue
common                                                     green                            tach wire                                   gray/black
Doors
wires from 6 wire harness                                 to truck
orange and ORANGE / black wire                          to ground
yellow and yellow/black wire                               to 12v constant
white wire                                                               to ORANGE / purple door lock wire
WHITE/ black wire                                                      to pink/purple door unlock wire
I am going to include a picture of the Main Engine Installing Figure that was the only directions included with the alarm in another post shortly. If anyone can help at all I would greatly appreciate it. Thank you.
Kristina
Date Posted: July 30, 2006 at 9:09 PM
I can't seem to shrink the image small enough to fit the 30KB limit on here so I guess I can try to e-mail the Installing figure to someone if they think they can help. Thanks for your time.
Kristina
Posted By: KarTuneMan
Date Posted: July 30, 2006 at 9:59 PM
These are your door lock control wires from the alarm. Your unit has built in relays. no= pin 87. nc= pin 87a. common= pin 30. Pins 85, and86 are controlled internally by the alarm.
hs-100 that I bought on ebay. This was  the first problem......
Can you post a link to the istall instruction? Heres a link for the color and location of the wires in the truck.
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1995-97&make=Dodge&model=Ram%20Pickup&ID=17654&type=Alarm This is what you need to "match up" to the alarm wires.....
