capacitor, what/where to purchase?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81099
Printed Date: June 17, 2024 at 12:36 AM
Topic: capacitor, what/where to purchase?
Posted By: profuse007
Subject: capacitor, what/where to purchase?
Date Posted: August 02, 2006 at 12:30 PM
capacitor 10k uF
application: pulse to steady
i found some capacitor on mouser.com but im not sure if its applicable and cheapest place to get it from.
peace
------------- Houston,TX
Posted By: Mad Scientists
Date Posted: August 02, 2006 at 4:03 PM
What are you trying to do with the capacitor? That's not a size generally though of when talking about power conditioning.. Jim
Posted By: captainzab
Date Posted: August 02, 2006 at 7:46 PM
https://www.the12volt.com/relays/page5.asp#pts
Where do people buy capacitors for this set up?
Posted By: dualsport
Date Posted: August 02, 2006 at 8:13 PM
While it's reliable and pretty foolproof, using the big cap method shown, a cheaper alternative is to use a transistor and a much smaller cap to do the timing. Pretty simple to do, but just needs a little more work to connect up.
Posted By: bdl666
Date Posted: August 02, 2006 at 9:05 PM
www.digikey.com ------------- ieSpell rocks.
Date Posted: August 02, 2006 at 9:12 PM
This does the same thing without needing the huge cap- If you have really slow pulses coming in, just increase the cap or resistor to lengthen the hold time.
Date Posted: August 02, 2006 at 9:51 PM
thanks for the diagram, but that wiring will be a load.
i guess ill order some cap from mouser.com.
Posted By: killer sonata
Date Posted: August 02, 2006 at 10:21 PM
upgrade you big 3 and your alternator first. you might not ever need a cap if you take care of the essentials first.
------------- "People with mullets live 40% longer" - Ricky Bobby
Posted By: Powermyster
Date Posted: August 03, 2006 at 3:40 AM
I don't think its an amp power cap he is looking for is it..
------------- Why oh Why didn't i take the blue pill
Darren Power
Date Posted: August 03, 2006 at 10:16 AM
Yeah, the cap's not for filtering, just for timing purposes.
If you have some experience installing alarms, it's not really that bad to wire up-
Date Posted: August 03, 2006 at 4:19 PM
For small quantities of electronics parts like that I'd look at Radio Shack.. but I've also used Digikey, Mouser, JDR Microdevices and others.. for the circuit you could also work up something based on a 555 timer circuit, but the RC network you're thinking about should work fine. Jim
Date Posted: August 03, 2006 at 11:20 PM
thanks everyone for the replies, but i went ahead and ordered some from mouser.com. radioshack charges an arm forthose type of stuff. i.e. spdt relay= 7bucks.
tran
