Suggest Security With Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82152
Printed Date: June 15, 2024 at 5:03 PM
Topic: Suggest Security With Remote Start
Posted By: faysal
Subject: Suggest Security With Remote Start
Date Posted: August 28, 2006 at 12:58 AM
hi pplz,
could you please suggest atleast 2 top/best Security System with Remote start (combo)? thank in advance to chip-in.
Posted By: dea,can
Date Posted: August 28, 2006 at 3:10 AM
depends what u are looking for in options what kinds of ride you have and like to protect it LCD 2way gives more for the dollar is Compustar - 2WSS-AS - Two-Way Alarm / Remote Starter 900MHz Spread Spectrum, 1-Remote up to 1.25 Mile range 2WSSAS
------------- dragon
Posted By: jesselyons2002
Date Posted: August 28, 2006 at 3:57 AM
Yeah Either the DEI Viper 791XV or Compustar 2WSS-AS. Both on this system have:
Security
Keyless entry
Remote start
LCD 2 way Pager remote
Use with either type of tranmisson.
------------- I Love my Crimestoppers
Posted By: faysal
Date Posted: August 28, 2006 at 10:46 AM
thanks everyone, as far as options matters, i'm not too sure, all i need is to protect my audio system, with remote start, so in winter it's get little easy :) ride is Honda Civic 2002 4 door. anybody can tell how's Delta Pro 5005 combo & UltraStart U4265 / Autopage RS-855LCD? please advice.
Posted By: KarTuneMan
Date Posted: August 28, 2006 at 11:49 AM
Hey...since your up there in Canada....look for an Astrostart dealer. www.astroflex.com A NEW division of DEI...oh it kills me to say that!
Posted By: spookiestylez
Date Posted: August 28, 2006 at 12:07 PM
Those are all really nice, Im going to put one out there just as an option, I dont have any experience w/ it but hopefully soon I will. If it all works out I might buy one for myself. Its call the Scytek Vision Guard 8000 features are: - Full Color Camera with Night Vision
- Automatic picture capture upon security violation
- Selective picture capture through the remote
- Store and recall up to ten discrete images on the LCD remote.
- One Carbon Fiber 2-Way True Color Picture remote control.
- One Carbon Fiber Slick 5-Button Remote With Super Bright Blue LED
- Built-In Parking-Light Relay Programmable (+/-)
- One 5 button code hopping remote control Sleek Carbon Fiber with Super Bright Blue LED
- Plug In LED and Override Switch
- Remote Start Tachless Mode using Adaptive Digital Signal Processing -compatible with all vehicles
- Remote Start Tach Monitor
- Starter Interrupt Output
- Dual stage Electronic Impact sensor
- Power door lock control
- Trunk Release
- Parking Light Flasher programmable polarity
- Courtesy Light Control
- Anti-grind Option
- Gas or Diesel compatibility
- Cold Start timer
- Selectable Engine Run Time
- Turbo Timer (adjustable)
- Smart Network Port
- Easy programming Via your PC, Pocket PC or Valet sw. and Remote Transmitter
- Lifetime Warranty
------------- RTFM
Date Posted: August 28, 2006 at 6:59 PM
So this thing has a camera you mount...somewhere, and it takes your picture when you break in? WoW. Honestly, it just sounds like more work to install...for features that, well, I think serve no real purpose. Just my opinion. If you have so little experiance, are you sure you want to learn on this type of unit? Consider one that you can get some qualified help on. (from the 12volt.....ya know) Plug In LED and Override Switch Remote Start Tachless Mode using Adaptive Digital Signal Processing -compatible with all vehicles Remote Start Tach Monitor Starter Interrupt Output Dual stage Electronic Impact sensor Power door lock control Trunk Release Parking Light Flasher programmable polarity Courtesy Light Control Anti-grind Option Gas or Diesel compatibility Cold Start timer Selectable Engine Run Time Turbo Timer (adjustable) Lifetime Warranty These sound like standard features found on MOST alarm remote starts -------------
Posted By: customak47
Date Posted: August 28, 2006 at 7:22 PM
I like the Ultras personally....easy and CLEAN to install, easy to use, very versitle, lots of options, easy programming...... www.ultrastarters.com ------------- My rifle is my friend...
Posted By: faysal
Date Posted: August 29, 2006 at 3:03 PM
thank everyone for chip-in, "spookiestylez" Scytek Vision Guard 8000 is too little too much :) the cost is close to $500, so that is for sure not my budget.
i don't wanna go over USD$220 max.
i nerrow down to 3 models, so everyone plz advice top 2:
Compustar 2WSS-AS Alarm and Starter with 2 Way Paging
ULTRASTART U4265-2W
AUTOPAGE RS-855LCD 2WAY
Thanks!
Date Posted: August 29, 2006 at 4:09 PM
Get the compustar.
Posted By: xtremej
Date Posted: August 29, 2006 at 4:53 PM
Ultrastart 1st Compustar 2nd. My .02 ........ -------------
Posted By: faysal
Date Posted: August 29, 2006 at 11:51 PM
Thanks everyone, i've decide to buy UltraStart U4265-2W, i know compustar is famous one, but compustar is almost $100 expensive, as far as options goes, Ultrastar have long list, i hope i'm making right decision.
