Smartwindows, Window Roll up feature
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82479
Printed Date: June 11, 2024 at 6:48 AM
Topic: Smartwindows, Window Roll up feature
Posted By: airic1054
Subject: Smartwindows, Window Roll up feature
Date Posted: September 04, 2006 at 7:03 PM
Hi,
I've got a Clifford Arrow 5 with SmartWindows4 module. Does anyone know how to enable the window roll up feature when the system arms? I can roll the windows down via remote fine, but I cannot figure out how to make them roll up. The system is installed on a '92 Integra if that makes a difference.
Thanks,
Eric
Posted By: olds19vert
Date Posted: September 04, 2006 at 8:50 PM
When I installed mine on my Mustang I used the Orange Grounded when Armed wire to the Modules. That made them roll up when Armed. Not sure if mine are the same Modules as yours.
Posted By: Raymond4646
Date Posted: September 04, 2006 at 9:05 PM
On my mustang I have a Intellaguard 8000 with SmartWindows4 and if "I" arm the security system then the windows will go up. If I let the system passively arm then the window will not go up. You need to check to see if the ground when armed wire is hooked up.
Date Posted: September 05, 2006 at 2:15 AM
Thanks for the quick replys! You mean the orange wire on the main alarm unit, right? Which wire did you tie it into on the window control module? None of the instruction/installation manuals I've come across clearly addresses this. Also, will I have to set something up within the Clifford Wizard to have the windows roll up? Thanks again.
Posted By: scirocco16v
Date Posted: September 05, 2006 at 10:12 PM
No ground when armed wire needed on smart windows 4, all communication through the dataport. Never seen this before. Does the one touch feature work when you tap on the cars window switches with the ignition on. they should go all the way up. I would suggest reprogramming the windows through the programming grid or wizard. the windows will roll up whenever you remotely arm the system with or without chirps. This cannot be turned off through the wizard.
Date Posted: September 07, 2006 at 1:10 AM
No, the windows don't roll all the way up when I tap the switch. I ran the smartwindows wires to the drivers side switch panel. I've tried programming the windows several times.
I start with the windows down, per the manual, run the programming module, and tap up on the first window switch. The program runs, cycles the windows up and down several times and ends by venting both about 2 inches. Is there something else I need to check off in Cliffnet Wizard Pro?
Thanks!
Date Posted: September 07, 2006 at 4:33 PM
I have seen everything on clifford systems and yet I am at a loss, it is doing everything it should. I am leaning towards a bad unit. I am since out of the business since G5 but there was nothing in the g4 line that needed to be changed in the wizard to make windows roll up on arming. The bottom line if you don't get one touch up to work that is also part of the problem. Are the windows really slow or have alot of resistance when going up. Also instead of using wizard to program do it through the programming grid. I believe I had to do that before. Sorry and good luck
Date Posted: September 15, 2006 at 9:44 PM
The one touch up and down functions work, I still haven't tried reprogramming through the programming grid. Is there something I have to set up for the remote? i.e. hit my "window function" key after arming like after disarming to vent? The windows don't roll down slow, nor do they have resistance. I'll try reprogramming via the grid once I find my user manual. Any other suggestions? I "think" everything is set up as it should be...
Thanks again.
