97 honda accord code alarm problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83059
Printed Date: June 06, 2024 at 9:58 AM
Topic: 97 honda accord code alarm problem
Posted By: cjyoung1113
Subject: 97 honda accord code alarm problem
Date Posted: September 18, 2006 at 6:43 PM
I am having a problem with my code alrm elite DM 1500. I went to start my car and it wouldnt start and one minute later my alarm started going off. I havent used it in a year or more. I didnt know what to do so I ripped off the horn to stop the embarrassment. Then I started unplugging the wires because I figured that would stop it. Now my car doesnt start at all. What should I do. I have no manual to plug the wires back in. There are two whites a black a red a green and a blue and I am cluless.
Posted By: cavsfan
Date Posted: September 18, 2006 at 7:50 PM
There should be a white and a WHITE/ red wire, connect them together and the car should start.
Date Posted: September 18, 2006 at 10:30 PM
Thank you for the advice. So I wont be using the alarm box at all?
Posted By: Velocity Motors
Date Posted: September 18, 2006 at 10:51 PM
At the ignition harness you will see a BLACK/ WHITE wire ( this is your starter wire ) and it's most likely cut in two. You will need to reconnect this wire to in order to have the starter crank.
------------- Jeff
Posted By: swamprat323
Date Posted: September 18, 2006 at 10:58 PM
code alarm DM elite 1500 is now in the down load section the install guide
Date Posted: September 18, 2006 at 10:59 PM
Im car illiterate, where is the ignition harness? Why is it cut? Is it cut from when thet installed the alarm? Will connecting these wires bypass going through the alarm.
Date Posted: September 19, 2006 at 9:04 AM
Would for some reason the battery be dead now because the car still wont start. It turns over once and thats it
Date Posted: September 19, 2006 at 11:25 AM
on the alarm find the white wire and the white with a red strip. slpice these wires toghter, this go to the start kill. once these wires are toghter the car should start, that if ther is nothign wrong with the car.
