06 Acura TSX wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83163
Printed Date: May 02, 2024 at 1:02 AM
Topic: 06 Acura TSX wiring
Posted By: wblakes
Subject: 06 Acura TSX wiring
Date Posted: September 20, 2006 at 11:59 PM
can someone give me the wiring the car please. i've tried using the 05 TSX wiring but it's a little different. so far i've noticed that the power lock wires and the horn trigger wire is different. thank you..
Posted By: JWorm
Date Posted: September 21, 2006 at 12:41 AM
It looks like the colors change at some point....probably at a molex plug somewhere.
Here is what I noticed different between tech sheets for the two years.
2006 TSX
Power Lock pink/black to pink - MICU, green 30 pin plug, pin 25
Notes: Meter this wire while using the passenger door lock switch.
Power Unlock pink/blue to lt. blue - MICU, green 30 pin plug, pin 9
The MICU (Multiplex Integrated Control Unit) is part of the fuse box in the driver kick. It has two connectors on the edge of the fuse box facing the rear of the vehicle.
Keysense red - ign harn or MICU, grn 30P plg, pin13
Horn Trigger green to GREEN/ YELLOW - horn switch
Memory Seat 1 blue - driver kick, door harness
Memory Seat 2 blue / YELLOW - driver kick, door harness
Posted By: wblakes
Date Posted: September 21, 2006 at 8:24 AM
thank you so much, i'll give it a try.
Posted By: wblakes
Date Posted: October 02, 2006 at 8:18 PM
ok i finished the installation and i'm having a small problem now with the tach wire. the wiring diagram said the tach wire is "blue at the ECM in the white plug". i've tried all the blue wires at the white plug and none of them came out to be the tach wire. for some reason i remembered using a white wire in that plug in the 2005 TSX, so i tried that and it worked. i now use the white wire, but sometimes when i remote started it; it would start on first attempt and sometimes it won't start until second attempt. the question is do you think i have the wrong tach or my bypass is acting up??
Posted By: shaggy12volt
Date Posted: October 02, 2006 at 8:37 PM
Tachometer | NOT blk/wht, black or yel/blk | ac | any ignition coil or fuel injector |
try this might hlep ya ------------- The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Posted By: wblakes
Date Posted: October 02, 2006 at 11:15 PM
thanks for the info, but since i already have the wire at the ECM i was wondering if there is another wire that i was suppose to use besides blue.
Posted By: wblakes
Date Posted: October 23, 2006 at 1:47 PM
2006 TSX
is there a different tach wire or different pin # for 2006 TSX? i unplugged the 31pin white plug at the ECU and pin #25 is empty but pin #26 is blue.
