need wiring info on a 2003 BMW 760Li
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83848
Printed Date: April 27, 2024 at 5:23 PM
Topic: need wiring info on a 2003 BMW 760Li
Posted By: stevet
Subject: need wiring info on a 2003 BMW 760Li
Date Posted: October 07, 2006 at 8:48 PM
Looking on what wires to to tap onto to supply 12v+, 12v+ Swithed and color of wire to interrupt starter for ignition kill. On this vehicle it has a lower knee air bag, does this need to come off as I see no access to get behind the ignition switch. This also is a keyless trasponder ignition system.
What can I do? Please advise
Posted By: JWorm
Date Posted: October 09, 2006 at 4:54 PM
What are you actually doing to the car? I haven't done one myself...
I have heard the best place to find a switched ignition wire under the dash in that car is at the brake switch.
Constant, I would go to the battery. Maybe an in car fusebox, but it may cause computer problems.
Starter wire...what for? If you are doing a starter kill....why bother? Those cars don't get stolen by getting hotwired, they get stolen on a tow truck.
Posted By: stevet
Date Posted: October 09, 2006 at 9:58 PM
I install for credit unions for folks with bad credit or low fico scores and this system put's them in check. A GPS tracking system and a voice activated kill switch so it's not like it for security at all but more for credit unions benifit. If it get's towed the the benifit goes to both parties as they still hold interest in the vehicle. That is why the starter circuit is ness.....
That and I still need answers if anyone has done one.
Steve
Posted By: JWorm
Date Posted: October 12, 2006 at 7:36 PM
As far as I know, the wiring going up to the ignition switch is CAN BUS. There is not a typical starter wire. Nobody makes a module to remote start the car, so good luck finding someone that has done one. You may be better off trying to interupt a fuel pump wire or something. No matter what you do, you'll probably trigger a check engine light.
What is a person with a bad credit score buying a 7 series for? Sounds like they should be taking care of some other bills before dropping money on a car that costs that much.
Posted By: gcorrea
Date Posted: October 12, 2006 at 7:46 PM
DIRECTWIRE™ WIRING INFORMATION - BMW / 7 SERIES / 2001 / Remote Start
[PRINT THIS PAGE]
12volts red + ignition harness
Starter BLACK / YELLOW + ignition harness
Second Starter N/A
Ignition green (x3) + ignition harness
Second Ignition purple + ignition harness
Third Ignition N/A
Accessory N/A
Second Accessory N/A
Keysense
Power Lock blue/red + driver door module in door
Power Unlock BLACK/ white or WHITE/ black + driver door module in door
Lock Motor
Unlock Motor
Parking Lights+ black headlight switch
Notes: Cutting this wire turns on the parking lights. Use a relay to interrupt the wire to flash the parking lights. See DirectFax document 1055 for wiring information.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blue/red + dome light
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white - trunk pin
Hood Pin PURPLE / green - hood pin
Trunk/Hatch Release gray/brown - release switch
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black ac round diag. plug under hood
Wait to start N/A
Brake Wire BROWN / gray + brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
EWS III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
hope this helps out a little.
------------- gcorrea
Posted By: stevet
Date Posted: October 13, 2006 at 10:14 AM
Thanks but the Li's are different monsters all together, if you looked at the other posts above they are all buss to ECMs or computors and send low voltage signals to control things. I did however go to a BMW dealer and drilled one of there techs and they showed me a few things about it. I just need more feedback from someone who has tested one and successfully installed some kind of aftermarket item needing those same circuitry I need somewhere under the dash.
Thank Keep em coming because someone here is bound to need the same info.
Posted By: Chris Luongo
Date Posted: October 16, 2006 at 7:08 PM
Hmm, I have an idea.
The goal is that the car can't be driven when it's not supposed to be driven, correct?
Would your client be satisfied if the engine would start, but the car was still undriveable? It might be difficult to explain to them.......
But if the brake swtich is accessible.......and you need to step on the brake to get the car out of Park.........maybe you could just interrupt the brake wire? They could start the car, but they couldn't go anywhere.
Another idea would be to search the fuse/relay box and see if you could find a starter relay............. I'm still trying to think of how you could use that to your advantage, though.
Posted By: stevet
Date Posted: October 16, 2006 at 9:22 PM
Chris, thank you the brake switch is a good idea if it allows the shifter not to disingauge out of park that would serve the same purpose. Why didn't I think of that? Duhhhhh! I will have to do more research on that with the dealership.
Posted By: stevet
Date Posted: October 17, 2006 at 10:04 AM
Anyone else? I would like to hear from someone that has done a 750Li or the 760Li.
Thanks!
Posted By: integratyper934
Date Posted: October 20, 2006 at 2:54 AM
i hope your getting paid good for that job, otherwise whats the point of using up the time and probably throwing light.
Posted By: stevet
Date Posted: October 21, 2006 at 10:32 AM
integratype, no matter the job or how much you get paid reasearch and gathering knowledge is part of the job even if you have to pay for it. Why are you here? Same thing.
