07 Suburban Door lock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84322
Printed Date: May 29, 2024 at 4:44 AM
Topic: 07 Suburban Door lock problem
Posted By: csorb
Subject: 07 Suburban Door lock problem
Date Posted: October 19, 2006 at 12:55 AM
Did a Remote Start/Alarm on this one. Used the xk01-gmdl6. After locking with the remote and then unlocking the doors unlock fine but then for some reason lock again on their own. If I hit unlock again, they stay unlocked. Anybody seen this?
Posted By: Hymer
Date Posted: October 19, 2006 at 9:55 AM
see what the vehicles lock options are programed for on the instrument cluster... what year burban?
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: csorb
Date Posted: October 24, 2006 at 9:39 AM
Solved the problem. The brown wire into the xko1 was being pulsed during unlock. The removal of ground from this wire causes doors to lock. We just used a different ground out when running.
Posted By: Hymer
Date Posted: October 24, 2006 at 9:45 AM
Note to self "make sure not to pulse the ground out when running on dl modules".. Heh glad ya found it...
Posted By: csorb
Date Posted: October 29, 2006 at 3:38 PM
You have to connect the ground out when running, otherwise the factory alarm will go off when you remote start. Just make sure to have it on steady and not pulsed. Thanks
