Does any one have any wiring info on this car? Or know where the factory keyless entry module is?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Iknow the wires are blue & white in harness above fuseblock in dkp
Dave
No takers huh? Well I have to do it tommarow and I will post what I find.
i did one last week - heres what i can remember off the top of my head
12V=Green, Ignition=Yellow, Starter=Red, Accy=White, 2nd Accy=Orange : All found in the ignition harness
Locks are negative trigger, and are located a white connecter (the uppermost and centermost) of a 4 connecter cluster located on the left side of the underdash Blue and White - I cant recall which locks and unlocks
Parking lights (+) =RED / Black @ the dimmer switch, Fog Lamps (+)=Blue @ plug on left side high in the steering column
Brake Wire= (+) White wire (i think) at the break switch
Door Trigger (+)= RED / Black, In a white connecter below the fuse box the wire is one of two wires exiting the same pin in the connecter (I believe this wire feeds the dome light because this will read for all 4 doors, the rear hatch, and the hatch glass
Power Hatch glass release (+) RED / Orange, in a harness entering the car from the drivers door
I could not find tach for this vehicle, I hope this helps a bit, just remember to double check everything because this is off the top of my head
Thanx. I will get every thing sorted out and post exact wiring for it
