2003 caravan remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84717
Printed Date: May 21, 2024 at 11:45 PM
Topic: 2003 caravan remote start
Posted By: bronco5000
Subject: 2003 caravan remote start
Date Posted: October 26, 2006 at 11:46 PM
installing a 3300 prostart in my brothers caravan with factory security. it will crank over but will not start. I need a wiring diagram for that make of van. I think I am missing a ignition wire. security is not shutting it down, it cranks for the 8 sec then trys over again. any help would be great. ps also need to know how to power up the heater motor ------------- any info is good info
Posted By: Mike M2
Date Posted: October 27, 2006 at 6:25 AM
12volts | lt. blue/red (10A) | + | ignition harness | Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to the battery for 12v. | Starter | yellow | + | ignition harness | Second Starter | PURPLE / brown | - | ignition harness | Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information. | Ignition | pink/white | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | not required for remote start |
Did you hook up the second starter wire? this will make it not start.... ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: kgerry
Date Posted: October 27, 2006 at 9:15 AM
also, what bypass module did you use? what color is the head of the key? ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: sparkie
Date Posted: October 27, 2006 at 2:47 PM
It sounds like you didn't hook up the relay to pulse the viloet/brown wire to ground through a 180 ohm resistor during crank. This is why it won't start and why the climate controls aren't working.
------------- sparky
Date Posted: October 28, 2006 at 12:44 AM
did not hook up the neg wire to starter(did not know about it lol)it must be a feed to the body control module
I did not hook up the accessories yet, which wire is it?
thanks
Posted By: green6767
Date Posted: October 28, 2006 at 6:57 AM
Accessory runs with ignition in those vehicles, so you dont need to hook it up. You only need to hook up 12V, ignition (pink/white), starter (yellow), and second starter (negative with 180 ohm resistor through a relay. If you didn't hook that up, the van is just gonna sit and crank. Also, which color is the head of the key for the van? If its grey, you need a bypass for the transponder type key. If its black, you wont need to bypass the key.
------------- Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
