DEI 564T 2 way remote replacement?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84775
Printed Date: May 16, 2024 at 11:27 AM
Topic: DEI 564T 2 way remote replacement?
Posted By: bbtaco
Subject: DEI 564T 2 way remote replacement?
Date Posted: October 28, 2006 at 6:50 PM
Will any of the other 2 way DEI remotes work with the Hornet 564T? Like the 488P Python LED remote?
Posted By: Big Dog
Date Posted: October 31, 2006 at 1:02 PM
The 488 will work but obviously you'll loose features.
------------- Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: bbtaco
Date Posted: November 03, 2006 at 7:20 PM
I have programmed a 488P LED remote to my 564T. The LED remote works but only as a one way remote? It indicates that it is out of range(no signal received?) when any of the buttons on it are pressed. So none of the LED's indicate that the signal went thru. The LCD 477T still works fine both ways. Any ideas as to what is wrong? Which antenna does the 564T come with? The manual just says it is an ASK system. I read that the 548T would work fine with the LCD and LED 2 way remotes. The one I have sure looks like the 548T that I have a picture of.
