06 Saab 93
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85086
Printed Date: May 03, 2024 at 1:07 PM
Topic: 06 Saab 93
Posted By: ziggyb222
Subject: 06 Saab 93
Date Posted: November 03, 2006 at 7:01 PM
Did a search on this 06 Saab 93 and not alot of info out there. Anyone have a wire guide and any suggestions on this car?? My Crimestopper site doesnt even list it....
Posted By: KarTuneMan
Date Posted: November 18, 2006 at 10:19 PM
Wire/Function Colour Location/Description Polarity
12 VOLTSWhite4-pin blue plug at steering column +
The wires change color on one side of this connector, verify both sides for these wires.
IGNITIONGreen4-pin blue plug at steering column +
ACCESSORYYellow4-pin blue plug at steering column +
STARTERWHITE/ black4-pin blue plug at steering column +
KEY SENSEWHITE/ redIn 2-pin black plug at steering column +
The wire changes to BLACK on the other side of the 2-pin connector.
TACH SIGNALBlue / YELLOWIn harness from ignition coils AC
On the 2L engine, the coils are very difficult to access. You can get a tach signal at the harness coming up the left side of the engine from 2 of the coils. See the available graphics
LOCKRED / whiteIn white 20-pin plug at Body ECU -
The Body ECU is located on the left side of the steering column.
UNLOCKYellow/redIn white 20-pin plug at Body ECU -
DOORPINYellowIn 16-pin connector at keyless entry module -
The keyless entry unit is found under the driver's side dash directly above the fusepanel. If the vehicle is not equipped with keyless entry, the white 16-pin connector can still be found here. See the available graphics.
TRUNK PINYellow/redIn 16-pin connector at keyless entry module -
TRUNK RELEASEManual release
BRAKESWITCHWHITE/ blackAt switch above brake pedal +
PARKLIGHTSOrangeIn main black harness at steering column +
You must test for this wire with the ignition switch turned ON.
HAND BRAKEPinkBelow handbrake in center console -
HORNGREEN/ redIn black 5-pin plug at steering column -
CLUTCH SWITCHGREEN/ YELLOWAt connector above clutch pedal TYPE 2
DRIVER WINDOW UPBlue/redOn back of window switch in driver's door REV POL
DRIVER WINDOW DOWNBlueOn back of window switch in driver's door REV POL
PASSENGER WINDOW UPRED / blueOn back of window switch in driver's door REV POL
PASSENGER WINDOW DOWNBLACK/ blueOn back of window switch in driver's door REV POL
VSS WIREGREEN/ YELLOWBehind instrument cluster AC
try this subaru info.....
