05 Honda Pilot, Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85323
Printed Date: May 02, 2024 at 9:45 PM
Topic: 05 Honda Pilot, Remote Start
Posted By: pitoaudiovisual
Subject: 05 Honda Pilot, Remote Start
Date Posted: October 24, 2006 at 10:29 AM
can anyone give me paper work for a 05 honda pilot for remote start and alarm please thanx in advance
------------- Confidence is the key to any project!!
Posted By: Twelvoltz
Date Posted: October 24, 2006 at 11:30 AM
Confidence
DIRECTWIRE™ WIRING INFORMATION - HONDA / PILOT / 2005 / Remote Start
[PRINT THIS PAGE]
12volts white (50A) + ignition harness Starter BLACK/ white + ignition harness Second Starter N/A Ignition BLACK / YELLOW + ignition harness Second Ignition N/A Third Ignition N/A Accessory yellow + ignition harness Second Accessory WHITE/ black + ignition harness Keysense blue/black (required) - ignition harness Power Lock BLACK/ orange - pass. fuse box, lt. grn 20 pin plug Notes: Meter this wire while pressing the passenger door lock switch. Power Unlock blue/orange - pass. fuse box, lt. grn 20 pin plug Notes: Meter this wire while pressing the passenger door lock switch. Lock Motor WHITE/ blue 5wi driver fuse box, lt. grn 18 pin plug Unlock Motor yellow or lt. GREEN/ red 5wi driver fuse box, lt. grn 18 pin plug Parking Lights+ RED / black + driver fuse box, lt. grn 20 pin plug Parking Lights- RED / yellow - headlight switch Hazards same as turn signal wires Turn Signal(L) GREEN / WHITE + turn signal switch Turn Signal(R) GREEN/ YELLOW + turn signal switch Reverse Light GREEN/ black + passenger kick, harness to rear Door Trigger BLACK/ white - interior light switch on dash Notes: The driver side door trigger wires are at the driver side fuse box, in a lt. green 10 pin plug. The LF door is GREEN/ orange in pin 3. The LR door is lt. GREEN/ black in pin 10.
The passenger side door trigger wires are at the passenger side fuse box, in a lt. green 20 pin plug. The RF door is WHITE/ orange in pin 16. The RR door is GREEN / WHITE in pin 14. Use all four wires and diode isolate each. Dome Supervision lt. green - interior light switch on dash Trunk/Hatch Pin blue/black to orange - driver multiplex ctrl unit, pin 8 Notes: The driver multiplex control unit is attached to the driver side fuse box. It has a green 22 pin plug on the side of the fuse box facing the firewall. Hood Pin yellow/red to yellow - driver multiplex ctrl unit, pin 6 Notes: The driver multiplex control unit is attached to the driver side fuse box. It has a green 22 pin plug on the side of the fuse box facing the firewall. Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm blue/white to blue/green - pass. fuse box, lt. grn 20 pin plug Notes: Meter this wire while turning the key in the passenger door key cylinder. This wire will also lock the doors. Factory Alarm Disarm BLACK/ red - pass. fuse box, lt. grn 20 pin plug Notes: Meter this wire while turning the key in the passenger door key cylinder. This wire will also unlock the doors. Disarm No Unlock BLACK/ red to blue - driver door module in door Notes: Meter this wire while turning the key in the driver door key cylinder. Tachometer blue ac driver fuse box, lt. grn 10 pin plug Notes: Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Can also go to any fuel injector and use the wire that is NOT yellow/black. Wait to start N/A Brake Wire WHITE/ black + brake pedal switch Parking Brake GREEN/ red or GREEN/ purple - driver multiplex ctrl unit, pin 15 Notes: The driver multiplex control unit is attached to the driver side fuse box. It has a green 22 pin plug on the side of the fuse box facing the firewall. Horn Trigger lt. GREEN/ blue - horn switch Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Transponder Part #: 556HW Alternate Part1 #: 556UW Alternate Part2 #: DesignTech 20402 Alternate Part3 #: DesignTech 29402 Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / yellow, data wire is RED / green and ignition wire is RED / white. Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Date Posted: November 01, 2006 at 8:43 PM
Im doing an 05 Honda Pilot and I want to do factory arm and its says to connect blue /white to blue/green. Just wanted to know if that ment to just connect them to each other or if I just have to use one or the other..Thanx in advance...
Date Posted: November 01, 2006 at 9:03 PM
That description is just explaining that the wire changes color somewhere.
Date Posted: November 08, 2006 at 9:10 AM
I installed a remote start on a 05 Honda Pilot and when he remote starts the car the factory alarm goes off and i thought it was the key sense but it is connected so I was wondering if I had to install the wire that says disarm no unlock .. thanx in advance.
Posted By: thepencil
Date Posted: November 08, 2006 at 11:56 AM
What about this part? Were you about to try this?
------------- Be careful whose advice you buy, but be patient with those who supply it.
Date Posted: November 08, 2006 at 3:21 PM
ok im goin to try that but i also have a question the car has day time running lights that turn on with the car and off when you arm the car but when the car is remote started and then when it turns off the lights stay on cause the factory alarm is not rearmed is there a way to rearm the factory alarm when the autostart is turned off . I installed a Prestige 996a..
Posted By: lsondubz
Date Posted: November 08, 2006 at 3:30 PM
I am doing an 06 Pilot Remote Start and Keyless tomorrow and was wondering about wiring problems with the dome light staying on?? It says keysense is required but what do I hook up to the keysense wire? Do I just run the keysense from the 556U there or do I need to run a status output to the keysense in the car? Also, I had a tip from someone else who told me that it would be alot easier to just pulse the factory alarm disarm wire and then just hook up a lock after start on the door locks, that sounds alot easier than going into the door...
Date Posted: November 09, 2006 at 8:06 AM
ok can you tell me how and keysense you can connect to the 556u but put a diode so that the ground doesnt go in reverse..
Posted By: lsondubz
Date Posted: November 09, 2006 at 9:43 AM
Use the factory disarm wire from the BLACK/ blue from 4-pin aux plug, run that to the BLACK/ red alarm disarm wire to Factory Alarm Disarm BLACK/ red - pass. fuse box, lt. grn 20 pin plug ,this will disarm the alarm and unlock the doors,
Then you need to run the BLACK/ green wire from the 4-pin aux plug to the Factory Alarm Arm blue/white to blue/green - pass. fuse box, lt. grn 20 pin plug this will rearm and lock the doors
Posted By: lsondubz
Date Posted: November 09, 2006 at 9:46 AM
Sorry that was all screwed up, I didnt proofread heres how it should read:
Use the pulse before start wire BLACK/ blue from 4-pin aux plug, run that to Factory Alarm Disarm BLACK/ red - pass. fuse box, lt. grn 20 pin plug ,this will disarm the alarm and unlock the doors,
Then you need to run the pulse after start wire BLACK/ green wire from the 4-pin aux plug to the Factory Alarm Arm blue/white to blue/green - pass. fuse box, lt. grn 20 pin plug, this will rearm the alarm and lock the doors
