Print Page | Close Window |
05 subaru forester diagramPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85455 Printed Date: May 15, 2024 at 1:46 PM Topic: 05 subaru forester diagram Posted By: greggsymington Subject: 05 subaru forester diagram Date Posted: November 10, 2006 at 8:38 PM Hope one of you guys have a diagram for an 05 subaru forester. Planning a remote start install. Thanks in advance.
Replies: Posted By: lsondubz Date Posted: November 11, 2006 at 9:03 AM DIRECTWIRE™ WIRING INFORMATION - SUBARU / FORESTER / 2005 / Remote Start
12volts white (50A) + ignition harness Starter WHITE/ blue + ignition harness Second Starter N/A Ignition green + ignition harness Second Ignition N/A Third Ignition N/A Accessory yellow + ignition harness Second Accessory N/A Keysense WHITE/ red + ignition harness Power Lock RED / white - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Power Unlock yellow/red - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Lock Motor lt. GREEN/ black 5wi integrated module, blue plug Notes: The integrated module is to the left of the steering column. Unlock Motor red 5wi integrated module, blue plug Notes: The integrated module is to the left of the steering column. Parking Lights+ BLACK/ red or orange + parking switch Parking Lights- BLACK/ pink - lighting switch Notes: The negative parking lights wire only works with the ignition on. Hazards same as turn signal wires Turn Signal(L) BLACK/ green + turn signal switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Turn Signal(R) lt. GREEN/ black + turn signal switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Reverse Light BROWN / yellow + passenger kick, harness to rear Door Trigger yellow - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Dome Supervision use door trigger wire Trunk/Hatch Pin common with door trigger wire Hood Pin N/A Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock factory remote only Tachometer green ac ECM, 35 pin plug, pin 10 Notes: The ECM (Engine Control Module) is below the glove box. The tach wire is also found behind the instrument cluster in the middle plug. On the turbo models, the tach wire is in the 34 pin plug, pin 23. Wait to start N/A Brake Wire WHITE/ black + brake pedal switch Parking Brake lt. green to lt. GREEN/ black - parking brake switch Horn Trigger RED / green - horn switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Transponder Part #: 556UW Alternate Part1 #: DesignTech 20402 Alternate Part2 #: DesignTech 29402 Notes: Standard on the 2.5 XT models. Posted By: lsondubz Date Posted: November 11, 2006 at 9:04 AM DIRECTWIRE™ WIRING INFORMATION - SUBARU / FORESTER / 2005 / Remote Start
12volts white (50A) + ignition harness Starter WHITE/ blue + ignition harness Second Starter N/A Ignition green + ignition harness Second Ignition N/A Third Ignition N/A Accessory yellow + ignition harness Second Accessory N/A Keysense WHITE/ red + ignition harness Power Lock RED / white - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Power Unlock yellow/red - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Lock Motor lt. GREEN/ black 5wi integrated module, blue plug Notes: The integrated module is to the left of the steering column. Unlock Motor red 5wi integrated module, blue plug Notes: The integrated module is to the left of the steering column. Parking Lights+ BLACK/ red or orange + parking switch Parking Lights- BLACK/ pink - lighting switch Notes: The negative parking lights wire only works with the ignition on. Hazards same as turn signal wires Turn Signal(L) BLACK/ green + turn signal switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Turn Signal(R) lt. GREEN/ black + turn signal switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Reverse Light BROWN / yellow + passenger kick, harness to rear Door Trigger yellow - integrated module, gray plug Notes: The integrated module is to the left of the steering column. Dome Supervision use door trigger wire Trunk/Hatch Pin common with door trigger wire Hood Pin N/A Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock factory remote only Tachometer green ac ECM, 35 pin plug, pin 10 Notes: The ECM (Engine Control Module) is below the glove box. The tach wire is also found behind the instrument cluster in the middle plug. On the turbo models, the tach wire is in the 34 pin plug, pin 23. Wait to start N/A Brake Wire WHITE/ black + brake pedal switch Parking Brake lt. green to lt. GREEN/ black - parking brake switch Horn Trigger RED / green - horn switch or keyless Notes: The keyless entry control module is above the passenger kick panel. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Transponder Part #: 556UW Alternate Part1 #: DesignTech 20402 Alternate Part2 #: DesignTech 29402 Notes: Standard on the 2.5 XT models. |
