Autopage RS-620, 1998 olds intrigue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85625
Printed Date: May 15, 2024 at 3:29 PM
Topic: Autopage RS-620, 1998 olds intrigue
Posted By: black cavy
Subject: Autopage RS-620, 1998 olds intrigue
Date Posted: November 14, 2006 at 4:25 PM
Alright the car is a 1998 olds intriuge
Now i've installed many 2 way combo units before but i need help with this one LOL. Its very silly i know.Theres acuple feat i don't understand but i think there are the same thing.1,WHITE/ Blue wire (-) instant start and turn off out put.This wire activates and turns off the remote starter each time it sees a momentary ground signal.use to intergrate with factory or aftermarket system.!pulse is for an aftermarket alarm and 3 pulse is for a facotry system.2,yellow wire(-) 200 ma ign 3 control output.I fully understand what wire this is,as i need this for the bypass module.Now about the factory alarm,do i take both the disarm and rearm wire from the new alarm and t-tap that on the factory disarm wire???Never had to worry because i would always just put the factory alarm to sleep as there where getting a combo unit.So that blue wire did i need it???I know im probly reading into it to much,but i need to be 100% right before i tackle the job.See its for my grandma,and well i really just want her to have the RS feat,but i know the factory remotes won't work well its running.
Date Posted: November 15, 2006 at 9:41 PM
Any help here
Posted By: Twelvoltz
Date Posted: November 15, 2006 at 10:15 PM
According to DEI there is no factory alarm in the 1998 Intrigue. So you would not use the factory alarm arm/disarm wires.
If your factory remotes do not operate after the vehicle is started, then you would have to use a key to open the door when it is running. I would suggest just installing the after market system and using the remotes provided with it. This will provide substantially better range than the factory remotes and will work with the vehicle remote started. This also means that you would not need to concern yourself with the WHITE/ blue instant start and turn off.
Date Posted: November 16, 2006 at 9:32 PM
I just wanted to know could i take the horn honk out put wire on the RS/keyless entry and attach that to a siren unstead of the horn.Im not too sure if that wire is the same as the siren wire when just doing a alarm???also if i dont use that wire,can i just take that (-) wire and t-tap that right to the horn wire (-) with out useing a relay.what would happen???
Posted By: lsondubz
Date Posted: November 16, 2006 at 9:49 PM
Well the - horn honk wire can be hooked up to the - horn wire in the car no problem, if you want to use a siren instead, you just need to wire a relay to trigger power to the siren...
Date Posted: November 16, 2006 at 10:32 PM
I was just looking in my 620 manual and i don't have any (-),(+) door pin supervisor wires.I mean this is a RS/Keyless entry.How is the brain suppost to know that the door is open i even took a pic to show what i mean.How would i go about adding this feature???or isit not possible
its a 1998 Cavailer that its going in
posted_image
posted_image
And yes my hand is very shacky
But can it be done???,if not how does the alarm know if the door is open
