2006 Pontiac G6 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85680
Printed Date: May 17, 2024 at 7:32 PM
Topic: 2006 Pontiac G6 remote start
Posted By: SoundAudio
Subject: 2006 Pontiac G6 remote start
Date Posted: November 15, 2006 at 5:39 PM
I need the wiring info for a 2006 pontiac G6. Thank you very much.
Good Luck!
-Thad
Posted By: zerepdivad
Date Posted: November 15, 2006 at 8:49 PM
for what? the radio? alarm/remote start? little more specific
Date Posted: November 16, 2006 at 12:20 AM
Alarm/Remote Start
sorry
Good Luck!
-Thad
Date Posted: November 16, 2006 at 12:26 AM
SoundAudio wrote:
Alarm/Remote Start
sorry
12volts      RED / white (2A)       +       ignition harness
Starter      yel or pur/wh (not for rem st)      -,+      PCM, blue plug, pin 23 or 26
Notes: Starter wire is not required for remote start. When the vehicle sees that the ignition wire has voltage and the accessory wire lose voltage, it automatically cranks the starter.
The PCM (Powertrain Control Module) is in front of the battery on the driver side fender.
Second Starter      N/A
Ignition      pink       +       ign harn or BCM, C4, pin D3
Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Second Ignition      N/A
Third Ignition      N/A
Accessory      brown       +       ign harn or BCM, C4, pin C8
Second Accessory      N/A
Keysense      not required
Power Lock      white       -       driver kick or BCM, C1, pin 66
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays.
Power Unlock      same as power lock wire
Lock Motor      gray/black to gray       5wi      driver kick or BCM, C3, pin A5
Unlock Motor      tan       5wi      driver kick or BCM, C3, pin B1
Parking Lights+      brown       +       BCM, C3, pin A7
Parking Lights-      BROWN / white       -       switch or BCM, C2, pin 5
Hazards      white       -       switch or BCM, C2, pin 9
Turn Signal(L)      lt. blue/white (F), yellow (R)      +       BCM, C1, pin 38 and C3, pin A9
Turn Signal(R)      dk. blu/wht (F), dk. green (R)      +       BCM, C1, pin 56 and C3, pin A12
Reverse Light      lt. green       +       inside rearview mirror
Door Trigger      gray/black (D), tan/white (P)       -       each kick or BCM, C1, pins 51 and 72
Notes: Use both wires and diode isolate each.
Dome Supervision      gray       -       BCM, C3, pin A10
Trunk/Hatch Pin      ORANGE / black       -       BCM, C1, pin 18
Hood Pin      pink/black       -       pin switch or BCM, C1, pin 69
Trunk/Hatch Release      BROWN / white       -       BCM, C1, pin 71
The trunk release motor wire is tan/white (+) at the rear fuse block in the driver side of the trunk, black plug, pin F10.
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Passkey
Tachometer      NOT pink       ac       any fuel injector
Wait to start      N/A
Brake Wire      white       +       BCM, C1, pin 42
Parking Brake      lt. blue       -       switch or BCM, C1, pin 59
Horn Trigger      tan       -       switch or BCM, C2, pin 14
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
PASS-Key III+
Part #: OM-GMC-6
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models. In addition to the bypass module, you will also need to follow the interface information on DirectFax document 1603 using a 1300 ohm resistor.
Door Lock Interface      Required:
No      Type:
Data Bus
Part #: IM-GMSD-1
Alternate Part1 #: 456LW
There ya go hope it goes good for ya.
Date Posted: November 16, 2006 at 2:57 PM
Is it worth getting the data bus doorlock and factory alarm interface or just use the a resistor and relays for the door locks and ignore the factory alarm?  I already have the immobilizer bypass. Thanks.
Good Luck!
-Thad
Date Posted: November 16, 2006 at 3:37 PM
interfaces make things a lot smoother for the installs. i guess that's totally up to you.
A DMM is a beautiful thing.
Posted By: prdjr165
Date Posted: November 17, 2006 at 4:37 AM
I just did one last week,I used a PKG7 bypass module and it worked great.The only glitch was I had to hook up my Crimestopper RS900 to a tach source to stay running.
