Altima doors lock unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85693
Printed Date: April 18, 2026 at 8:48 PM
Topic: Altima doors lock unlock
Posted By: muaiad97
Subject: Altima doors lock unlock
Date Posted: November 15, 2006 at 9:29 PM
hi all
this allmost 2 days i am working on altima 2004 to find  lock  unlock  wires i still cant find them  i checked all the wires  in the car but i cant find brown  and pink  wires  wiring diagram says pink and brown  at  bcm  thees tow colours not availble in this car .
any help  please
thanx
Posted By: redpeppers
Date Posted: November 15, 2006 at 9:35 PM
These wires are only available on vehicles with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
This will require you to wire into the drivers door switch
Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors.
pink/blue - Lock negitive
WHITE/ blue - Unlock negitive
Where theres is a wire there's a way.
Posted By: captainzab
Date Posted: November 15, 2006 at 9:45 PM
If your altima does not have the wire, (which some altima does not!) reason too long to state.
use factory alarm disarm for unlock and arm for lock.
diode the wires. (or use relays if u do not have diodes)
disarm is WHITE/ blue neg. at bcm
arm is pink/blue neg. at bcm
posted_image
must use diodes for lock and unlock.
do a search if u want to know why.
Note: You Always Dont Get What You Pay For.
Posted By: muaiad97
Date Posted: November 15, 2006 at 10:03 PM
hi
thanx for replay but i canot find thes wire in  BCM i found them  pink/blue and whit /blue at the swich insid driver door  not in bcm its hard to run the wires from the swich  to the unit i made sur i cheked all the wir in bcm  but ther is no wit/blu or pink/ blu.
Posted By: cntrylvr79
Date Posted: November 15, 2006 at 10:12 PM
It's not hard at all to run wires into the door of an altima.  Take the panel off.  Take out the speaker.  Disconnect the door harness inside the drivers kick and feed it out.  On average I'd say I spend about 10minutes running the wires.  As far as I can tell that's a lot less than the 2 days you're sayng you spent trying to get the locks inside the car.
Cause I'm So white and nerdy...
First Class Certi-fried installer
