2006 Hyundai Tiburon alarm/rs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85777
Printed Date: May 04, 2024 at 1:01 PM
Topic: 2006 Hyundai Tiburon alarm/rs
Posted By: forbidden
Subject: 2006 Hyundai Tiburon alarm/rs
Date Posted: November 17, 2006 at 4:58 PM
Need some info for this vehicle please. So far the locking system is being a real PITA.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: Mike M2
Date Posted: November 17, 2006 at 5:59 PM
12volts | red (x2)(common 30A) | + | ignition harness | Starter | white | + | ignition harness | Second Starter | N/A | | | Ignition | red | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | pink | + | ignition harness | Second Accessory | orange | + | ignition harness | Keysense | blue/orange | - | ignition harness | Power Lock | yellow or blue | F | BCM, 12 pin plug, pin 8 or 3 | Notes: The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob.
The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Power Unlock | same as power lock wire | | | Lock Motor | green | 5wi | BCM, 22 pin plug, pin 6 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Unlock Motor | GREEN/ black | 5wi | BCM, 22 pin plug, pin 8 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Parking Lights+ | pink/black (L), GREEN/ org (R) | + | BCM, 22 pin plug, pins 10 and 5 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Parking Lights- | blue/orange | - | headlight switch | Hazards | white | - | hazard switch | Turn Signal(L) | RED / orange | + | BCM, 22 pin plug, pin 13 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Turn Signal(R) | orange | + | BCM, 22 pin plug, pin 17 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Reverse Light | gray | + | BCM, 22 pin plug, pin 2 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Door Trigger | yellow | - | BCM, 22 pin plug, pin 11 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
The individual door trigger wires are also at the BCM in a 12 pin plug. The driver door is gray/black in pin 9. The passenger door is gray in pin 4. Use both wires and diode isolate each. | Dome Supervision | yellow | - | BCM, 8 pin plug, pin 3 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Trunk/Hatch Pin | GREEN/ black | - | BCM, 12 pin plug, pin 6 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Hood Pin | GREEN/ orange | - | BCM, rear 20 pin plug, pin 9 | Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. | Trunk/Hatch Release | blue | + | driver kick, harness to rear | Power Sliding Door | N/A | | | Factory Alarm Arm | factory remote only | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ign, acc, and key sense | | | Tachometer | white | ac | passenger kick, 23 pin plug, pin 4 | Wait to start | N/A | | | Brake Wire | white | + | brake pedal switch | Parking Brake | blue/black | - | driver kick, 18 pin plug, pin 2 | Horn Trigger | GREEN/ black | - | horn switch | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Transponder | Part #: OM-Hyundai-1 | Alternate Part1 #: 556UW |
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: KarTuneMan
Date Posted: November 18, 2006 at 4:46 AM
LOCK | Yellow | In harness from driver's door | - | | | This is a 1-wire doorlock system. Ground the wire to unlock the doors, and open the wire to lock them. See the doorlock diagram for exact wiring instructions. |
| UNLOCK | Yellow | In harness from driver's door | - | | | This is a 1-wire doorlock system. Ground the wire to unlock the doors, and open the wire to lock them. See the doorlock diagram for exact wiring instructions. |
break the lock/unlock wire with a relay using pins 87a and 30. take the lock output to pin 85, 12v to pin 86. unlock output to the inside (closest to the alarm brain) of the broken lock/unlock wire. (before the relay) -------------
Date Posted: November 18, 2006 at 7:13 AM
Found the wires, they were green and GREEN/ black 5 wire reverse polarity on the BCM. Clutch bypass was simple, it is a positive bypass. ------------- Top Secret, I can tell you but then my wife will kill me.
Date Posted: November 18, 2006 at 12:51 PM
If you have the choice of going to the lock motor itself, and wiring up for a 5 wire conection (times 2) or going to one wire, using 1 relay....wouldn't you take the easy way out. I'm just curious, cause alot of the tech info gives you 2 choices for lock/unlock.
