Print Page | Close Window |
directech tips? 05 chevy malibuPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85886 Printed Date: May 05, 2024 at 1:06 PM Topic: directech tips? 05 chevy malibu Posted By: gcorrea Subject: directech tips? 05 chevy malibu Date Posted: November 19, 2006 at 9:22 PM anyone got the directechs info, or diagram, on doing a starter kill on the new gm cars(05 chevy malibu) thanks in advance.
------------- gcorrea Replies: Posted By: CruisinS&S Date Posted: November 19, 2006 at 9:29 PM DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / MALIBU / 2005 / Remote Start
[PRINT THIS PAGE] 12volts RED / black (50A) + BCM, C3, pin D1 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Starter yellow (not for remote start) - PCM, blue plug, pin 48 or 23 Notes: Starter wire is not required for remote start. When the vehicle sees that the ignition wire has voltage and the accessory wire lose voltage, it automatically cranks the starter. The PCM (Powertrain Control Module) is in front of the battery on the driver side fender. Second Starter N/A Ignition pink + ign harn or BCM, C4, pin D3 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Second Ignition N/A Third Ignition N/A Accessory brown + ign harn or BCM, C4, pin C8 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Second Accessory N/A Keysense not required Power Lock white - driver kick or BCM, C1, pin 66 Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays. The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Power Unlock same as power lock wire Lock Motor gray/black to gray 5wi driver kick or BCM, C3, pin A5 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Unlock Motor tan 5wi driver kick or BCM, C3, pin B1 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Lights+ brown + driver kick or BCM, C3, pin A7 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Lights- BROWN / white - switch or BCM, C2, pin 5 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Hazards white - switch or BCM, C2, pin 9 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Turn Signal(L) dk. blue (F), yellow (R) + BCM, C1, pin 38 and C3, pin A9 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Turn Signal(R) dk. green (F), dk. green (R) + BCM, C1, pin 56 and C3, pin A12 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Reverse Light lt. green + fuse block, driver side of trunk Door Trigger gray/black (D), tan/white (P) - each kick or BCM, C1, pins 51 and 72 Notes: Use both wires and diode isolate each. The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Dome Supervision gray - BCM, C3, pin A10 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Trunk/Hatch Pin ORANGE / black - BCM, C1, pin 18 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Hood Pin pink/black - pin switch or BCM, C1, pin 69 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Trunk/Hatch Release BROWN / white - switch or BCM, C1, pin 71 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Power Sliding Door N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm purple - driver kick, door harness Notes: This wire will disarm the factory alarm if it has not been triggered, but might not disarm if it has. This wire will also unlock the doors with a double pulse. Disarm No Unlock with ignition and Passkey Tachometer NOT pink ac any fuel injector Wait to start N/A Brake Wire white + BCM, C1, pin 42 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Brake lt. blue - switch or BCM, C1, pin 59 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Horn Trigger tan - switch or BCM, C2, pin 14 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: PASS-Key III+ Part #: OM-GMC-6 Alternate Part1 #: 556UW Alternate Part2 #: DesignTech 20402 Alternate Part3 #: DesignTech 29402 Notes: Standard on all models. Interface Module: Category: Door Lock Interface Required: No Type: Data Bus Part #: IM-GMSD-1 Alternate Part1 #: 456LW Notes: Smart Starter Kill Relays: Relay Type: Starter Relay Location: Engine compartment fusebox, Driver side Part #: 6402A Notes: If equipped with factory remote start, SSKR not recommended This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. ------------- Cruisin Security And Sounds Posted By: gcorrea Date Posted: November 19, 2006 at 10:22 PM got wiring info already, just need the actual kill relay wiring diagram. thanks anyways.
------------- gcorrea Posted By: CruisinS&S Date Posted: November 19, 2006 at 10:26 PM do you mean the samrt starter kill relay or just how to kill the starter for an alarm. If you want to just kill the starter for alarm, just use the yellow starter wire. That is wht duirectwire gives the color and notes - not for rs
------------- Cruisin Security And Sounds Posted By: gcorrea Date Posted: November 19, 2006 at 10:42 PM yes just the kill.
------------- gcorrea Posted By: gcorrea Date Posted: November 19, 2006 at 10:44 PM do you know the actual wiring itself for the relay. im not using a dei alarm on the car, so the color codes on directhecs will be different.
------------- gcorrea |
