factory plug and play Keyless system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86206
Printed Date: May 23, 2024 at 11:51 AM
Topic: factory plug and play Keyless system
Posted By: astrosman1
Subject: factory plug and play Keyless system
Date Posted: November 26, 2006 at 7:53 AM
Hi Guys, I am new to this site. So far, I am quite impressed with the info here. Now, here is my question. Does Ford have a factory plug in the wiring harness for adding a keyless entry system...specifically, a factory keyless entry system? I purchased a factory keyless entry system from my local ford dealership and of course there are no instructions that come with the system. There is a note telling me to logon to a website, but it must be a "ford restricted" site as I have no ID and password to access that site. I have a 1999 F350 CrewCab and it has power windows/door locks. It doesnt have PATS from what I can tell - the ignition key is ordinary. Any help is appreciated much! Thanks guys! ------------- 1999 F150 Flareside
1999 F350 DRW
Posted By: mobilecustoms
Date Posted: November 26, 2006 at 8:21 AM
i dont believe so. the aftermarket factory systems splice wires just like any other system.
Posted By: cavsfan
Date Posted: November 26, 2006 at 8:46 AM
You have the Ford (Code-Alarm) dealer add on keyless entry. It is not plug and play it installs just like any aftermarket system.
Date Posted: November 26, 2006 at 11:49 AM
thanks for the replies - I am surprised there is no plug - I guess the workers on the production/assembly line at Ford sit there with wire cutters and splice the wires manually... not too smart considering they only make thousands of vehicles per year and cant put together a general harness to accomplish this in seconds rather than minutes or hours... rather disappointing to say the least ------------- 1999 F150 Flareside
1999 F350 DRW
Posted By: Hymer
Date Posted: November 26, 2006 at 5:04 PM
No, that isn't true.. if the truck is ordered with factory keyless, then it has a different locking system than the other.. adding one after the fact, then you need to splice into the 5 wire system... you woul think they would revese engineer it, but the oem's are not real bright when it comes to that, they never have been.. anyway adding keyless to that truck is a breeze, and no yo don't have a PATS system in it... Get this one, I have a 94 f350 crew cab with power windows in the front[factory] and maual in the rear [factory] how dumb...
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
