alarm wiring, 2002 Dodge Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86334
Printed Date: April 29, 2026 at 12:31 PM
Topic: alarm wiring, 2002 Dodge Ram
Posted By: thamorg
Subject: alarm wiring, 2002 Dodge Ram
Date Posted: November 28, 2006 at 11:48 AM
Hello all, what I need help with is a wiring diagram {colors&locations} for a 2002 Dodge Ram 1500 Sport 4 door 4.7lt. engine witch has 8 seperate coil packs.Thank you for any help you can provide.
DODGE DUB 1500
Posted By: KarTuneMan
Date Posted: November 28, 2006 at 12:17 PM
RAM FULL SIZE PICKUP  2002 -2003
 KEY T-HARNESS IMMOBILIZER
  CHRY KEY-1   N/A   CHRYSLER'S SENTRY ANTI-THEFT TRANSPONDER System (GRAY IGNITION KEY), Requires 791 Bypass Module and Extra Ignition Key
 PART  COLOR LOCATION
 12 VOLT CONSTANT  PINK/BLACK (+)   IGNITION SWITCH HARNESS
 STARTER YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLUE (+) 16 Gauge wire, See NOTE *4 IGNITION SWITCH HARNESS
 IGNITION 2 RED / WHITE (+) 16 Gauge wire, See NOTE *4 IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 GREEN (+) See NOTE *5  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 ORANGE (+) See NOTE *5  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) PURPLE / YELLOW (-) See NOTE *1  @ BACK of HEADLIGHT SWITCH on Dash
 PARKING LIGHTS ( + ) BLACK / YELLOW (+)  @ RELAY UNDER HOOD, at POWER CENTER
 POWER LOCK WHITE/ GREEN (1-Wire Door Lock System) See NOTE *2  IN DRIVERS KICK PANEL, in DOOR HARNESS, heading to REAR of vehicle, See DAIGRAM
 POWER UNLOCK Same wire, See DIAGRAM  See DIAGRAMS
 DOOR TRIGGER See NOTE *3
 DOMELIGHT SUPERVISION TAN (-), Requires #775 Relay  See NOTE *3
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLACK/ RED (-)  @ STEERING COLUMN HARNESS
 TACH ANY wire NOT DARK GREEN/ ORANGE  @ COIL PACK or FUEL INJECTOR
 WAIT TO START LIGHT See NOTE *6
 BRAKE WHITE/ TAN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  GREEN/ ORANGE (-) See NOTE *7  IN DRIVERS DOOR HARNESS
 ANTI-THEFT CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM  TRANSPONDER @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 the (-) Negative PARKING LIGHTS on this vehicle will require a (-)Negative thru a 330 or 1400 Ohm Resistor and an extra Relay part #775, to connect, See DIAGRAM NOTE *2 the Door Locking System is a 1-Wire, to LOCK requires a (-)Negative thru a 820 Ohm Resistor and to UNLOCK requires a (-)Negative thru a 330 Ohm Resistor, some units require 2 extra relays part #775, to connect, See DIAGRAM NOTE *3 the DRIVERS DOOR is a TAN (-), the DRIVERS REAR DOOR is a TAN/ORANGE (-) or a PURPLE / ORANGE (-), these wires are in the DRIVERS KICK PANEL. The PASSENGE DOOR is a TAN/RED (-) and the PASSENGER REAR DOOR is a TAN / YELLOW (-), these wires are in the PASSENGER KICK PANEL. When connecting to an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE. to connect, See DIAGRAM NOTE *4 use the BLUE 16 Gauge wire as IGNITION #1, DO NOT use the HEAVY GAUGE BLUE wire for IGNITION #1. The Ignition #2 wire, RED / WHITE, is also 16 Gauge, there will be (2) RED / WHITE wires of the same gauge in the Ignition Switch Harness, one wire will test 12 Volts constant all the time and the other will test as Ignition #2, only use the wires that tests like an Ignition wire. NOTE *5 When connecting to a Remote Starter, connect the Accessory wire from the unit to both the GREEN (+) Accessory #1 wire (Large Gauge wire) and the ORANGE (+) Accessory #2 wire (16 Gauge wire) in the Ignition Switch Harness. NOTE *6 the DIESEL tach wire is a GRAY/BLACK in the BLACK plug at the PCM (Powertrain Control Module) NOTE *7 the DISARM wire requires a (-) Negative thru a 480 Ohm Resistor and an extra relay part #775, to connect, See DIAGRAM
https://64.85.6.129/extrainfo/diagrams/26500_RAM-FULL-SIZE-PICKUP-_(-)%20NEGATIVE%20DOOR%20PIN%20ISOLATION%20CIRCUIT.pdf
Posted By: thamorg
Date Posted: November 28, 2006 at 12:24 PM
Thank you very much for your time and knowledge...
DODGE DUB 1500
