2004 VW Jetta 5 Speed Directechs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86579
Printed Date: May 29, 2024 at 3:58 AM
Topic: 2004 VW Jetta 5 Speed Directechs
Posted By: awsomedude
Subject: 2004 VW Jetta 5 Speed Directechs
Date Posted: December 03, 2006 at 4:25 PM
I am preparing to install a compustar 2W900FM-AS on a 2004 VW Jetta 5 speed. I found a wiring diagram in the wiring section, but it looks to be quite basic as far as immobolizers and clutch wires go, can someone provide me with a directechs wiring sheet, and let me know what I am in for, my friend tells me these cars are a pain.
Troy
Posted By: KarTuneMan
Date Posted: December 03, 2006 at 6:16 PM
Date Posted: December 03, 2006 at 10:01 PM
Can you re-post this, when I click the link, it does not work, maybe copy and paste it on the thread.
Troy
Date Posted: December 03, 2006 at 10:20 PM
That was a test.....it obviously failed.
Wire/FunctionCM3000ColourLocation/DescriptionPolarity
PASSIVE ANTI-THEFT BLACK (CN2) YES TRANSPONDER SEE NOTES
12 VOLTS RED (CN1) Red Ignition harness +
IGNITION GREEN (CN1) Black Ignition harness +
ACCESSORY WHITE (CN1) BLACK/ red Ignition harness +
STARTER YELLOW (CN1) RED / blue or RED / black Ignition harness +
KEY SENSE BROWN / red Ignition harness +
TACH SIGNAL YELLOW/BLACK (CN3) BLACK/ red At coil on firewall behind engine AC
If the coil is not present at the firewall, look for a GREEN/ YELLOW at the coil pack on the engine (2 cylinder signal). On the 2.8L engine the tach is VIOLET / YELLOW (2 cylinder signal) at the coil pack on the engine.
FUEL INJECTOR Opposite from RED / violet At any injector on engine AC
LOCK BLUE/BLACK (CN4) Yellow At module in driver's door -
This is a one wire system. Ground to unlock and ground through 1K-ohm resistor to lock.
UNLOCK BLUE (CN4) Yellow At module in driver's door -
DOORPIN RED / WHITE(-) or RED(+) (CN3) Blue/gray At alarm module on left of column -
This is the domelight output wire. If you need the separate door triggers, they are BROWN / YELLOW (driver's door), BROWN / VIOLET (passenger door). Both are found at the alarm module on the left side of the column.. However, if the vehicle is equipped with power windows, the wiring changes and you will have to go into each door to get the triggers.
HOODPIN GRAY/BLACK (CN3) BROWN / red At alarm module on left of column -
TRUNK PIN VIOLET/BLACK (CN3) BROWN / black At alarm module on left of column -
TRUNK RELEASE VIOLET/WHITE (-) (CN4) GREEN/ brown At alarm module on left of column -
FACTORY ARM ORANGE (CN5) Arms with lock wire
FACTORY DISARM ORANGE / WHITE (CN5) Disarms with unlock wire
A single pulse disarms the alarm, a double pulse will also unlock all the doors. FOR REMOTE START: The vehicle can be remote started without disarming the factory alarm by using a relay to open the BLACK/ BLUE wire (ignition sense) at the steering column during remote start. You will also have to run your remote starter's start output directly to the starter relay RED / BLACK on the back of the fusepanel to bypass the factory starter kill.
BRAKESWITCH LT.BLUE/WHITE (CN3) RED / black At switch above brake pedal +
PARKLIGHTS GREEN / WHITE (+) (CN1) or (-) (CN2) Gray/brown & Gray/purple At light switch harness +
Left and right parking light circuits are independent and must be isolated with diodes or relays. See the TIP diagram.
HAND BRAKE LT.BLUE (CN3) Manual only BROWN / yellow Behind relay #173 on fusepanel -
HORN WHITE (-) (CN5) BLACK / YELLOW Behind horn relay on fusepanel +
CLUTCH SWITCH Manuals only (see inst. Guide) RED / black Behind starter relay on fusepanel TYPE 1
DRIVER WINDOW UP Hold ground to lock wire
DRIVER WINDOW DOWN Hold ground to unlock wire
PASSENGER WINDOW UP Hold ground to lock wire
PASSENGER WINDOW DOWN Hold ground to unlock wire
LEFT REAR WINDOW UP Hold ground to lock wire
LEFT REAR WINDOW DOWN Hold ground to unlock wire
RIGHT REAR WINDOW UP Hold ground to lock wire
RIGHT REAR WINDOW DOWN Hold ground to unlock wire
HEADLIGHTS Yellow/red At light switch harness +
REVERSE LIGHTS BLACK/ blue In driver's kickpanel +
VSS WIRE Green Pin-28 of 32-pin plug behind cluster
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the ALARM diagram before any remote start installation.
