Which is better, Clifford or Compustar?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86622
Printed Date: May 13, 2024 at 8:52 PM
Topic: Which is better, Clifford or Compustar?
Posted By: bob smith
Subject: Which is better, Clifford or Compustar?
Date Posted: December 04, 2006 at 11:51 AM
I am going to get a basic car starter for Christmas from my wife. It looks like my choices are between the Clifford RS2.1 ($290 + tax) and the Compustar 1W900 ($325 + tax). Is one of these better than the other? It will be for a 96 Montel Carlo with a computer chip in the key. Both prices include a bypass mechanism.
The Clifford dealer was a Compustar dealer last year, but said they switched to Clifford because CS had too many problems in the past year or two.
Also, is $60-80 reasonable for a bypass module (installed)?
Posted By: spookiestylez
Date Posted: December 04, 2006 at 12:00 PM
I've heard a a few bad things about the CS starters also, but I've never used either one. I know DEI owns the Clifford brand, and from experience 99 of 100 from DEI products are great.Also $60-$80 for a bypass and install is normal. I 556u bypass from us is like $55 and install is $24.99
------------- RTFM
Posted By: kaezoo
Date Posted: December 04, 2006 at 12:04 PM
According to my information, your key has a VATS resistor pellet built in, not a computer chip. A bypass module isn't necessary; these can be bypassed with a standard relay and resistor.
Posted By: thepencil
Date Posted: December 04, 2006 at 1:49 PM
$60-$100 is a fair price.
I wouldn't worry too much about which brand to choose. That the least important part when making your purchases descision!
Look into the feature that you need and MOST EASIEST for the installer to applied it to the unit (you want to make their job easy too). Look into replacement cost of remote, how much it cost to program a new remote, who will stay around when your unit don't work anymore and most important, what do they $$cover$$ you when need someone to look into issue you have with the remote starter unit.
------------- Be careful whose advice you buy, but be patient with those who supply it.
Posted By: chadwa2003
Date Posted: December 04, 2006 at 3:40 PM
Both units are good the compustar warranty is lifetime on the brain and 1 yr on the remote, I'm pretty sure it would be the same on the clifford but you'd have to check on that in terms of ease of installation it would be the compustar in my opinion and the replacement remotes are pretty cheap. But I may just be biased but I just don't like clifford or dei in general
Date Posted: December 04, 2006 at 4:32 PM
If thats whats required, rather than a bypass module, is the $60 a fair price? It seems high to me, but I dont know much about any of this stuff.
All I want is my car to start from at least 6-10 blocks away.
Posted By: dre187
Date Posted: December 04, 2006 at 4:36 PM
$60-$80 is a reasonable price for the bypass module. I would say that both units are of quality and you don't have to worry about either going out of business anytime soon. Compustar isnt as "installer friendly" as clifford is and, therefore, could result in a sloppy install if the installer isnt very experienced. Ask the dealer which one has more range. that might be a deciding factor for you. all in all, both companies make good product, so don't worry too much about the quality.
Posted By: OhioMike1101
Date Posted: December 05, 2006 at 8:07 AM
Are you joking? Compustar is the most installer friendly alarm/RS units I have ever used. Maybe they aren't if you have a bad installer. ------------- South Side Audio
2501 S. High St
Columbus, OH 43207
Date Posted: December 05, 2006 at 10:40 AM
I agree with mike the are the easiest to install as well as program. Out of the two it would be the cleanest as long as they know what they are doing
Posted By: SoundAudio
Date Posted: December 05, 2006 at 11:27 AM
I personally sell and install Compustar. I have been very pleased with the every compustar unit I have done, and it is very easy to install. I don't have any experience with Clifford, but I would imagine that wouldn't be much different. An experienced installer that is familiar with either should have no problem. I think it should be the VATS system which can be done using a relay and resistor. Personally I just charge for the relay nothing extra because it takes like 10 minutes to do. If they use a bypass module then $60 is plenty resonable, but make sure you ask which method they are using.
------------- Good Luck!
-Thad
Date Posted: December 05, 2006 at 12:29 PM
How much does the relay normally cost?
Posted By: azn_fcuk
Date Posted: December 05, 2006 at 12:44 PM
good quality automotive relay and harness together from a supplier costs my $10 cad
