06 Nissan Pathfinder, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86988
Printed Date: May 04, 2024 at 12:48 AM
Topic: 06 Nissan Pathfinder, remote start
Posted By: pitoaudiovisual
Subject: 06 Nissan Pathfinder, remote start
Date Posted: December 10, 2006 at 8:42 PM
Does anyone have the paper work for an 06 Nissan Pathfinder for remote start .. thank you in advance.
------------- Confidence is the key to any project!!
Posted By: KarTuneMan
Date Posted: December 10, 2006 at 11:15 PM
Wire/Function | Colour | Location/Description | Polarity | PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | 12 VOLTS | Green | Ignition switch harness | + | IGNITION | WHITE/ green or BLACK/ red | Ignition switch harness | + | ACCESSORY | Red | Ignition switch harness | + | ACCESSORY 2 | GREEN/ YELLOW | Ignition switch harness | + | STARTER | Gray | Ignition switch harness | + | STARTER 2 | Lt. green | Ignition switch harness | + | KEY SENSE | Black | Ignition switch harness | + | TACH SIGNAL | Use an injector | | | FUEL INJECTOR | Opposite from WHITE/ green | At any injector on engine | AC | LOCK | Lt.blue | In driver's kickpanel | - | | | This wire can also be found at the BCM (Body Control Module) on the right side of the steering column. |
| UNLOCK | Gray (Double pulse) | In driver's kickpanel | - | | | This wire can also be found at the BCM (Body Control Module) on the right side of the steering column. |
| DOORPIN | Gray | In driver's kickpanel (harness to rear) | - | | | For separate doorpins use Gray (left front), Lt.green (right front), Pink (left rear) & Blue (right rear). All 4 wires are found at the BCM on the right side of the steering column, diode isolate. |
| TRUNK PIN | Yellow | At BCM on right of steering column | - | | | A Lt.green (-) will catch the rear window. This wire is found in the same location. |
| FACTORY ARM | Arms with lock wire | | | FACTORY DISARM | Disarms with unlock | | | BRAKESWITCH | Pink or Yellow | At switch above brake pedal | + | PARKLIGHTS | Red | Behind the mirror control | + | | | May also find a GRAY wire in the driver's kickpanel. |
| HORN | Brown | At steering column | - | REVERSE LIGHTS | Lt.blue | In driver's kickpanel | + | VSS WIRE | Lt.blue | In harness on back of radio | 8000PPM |
