1995 Nissan 240sx, remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87096
Printed Date: April 25, 2024 at 6:40 AM
Topic: 1995 Nissan 240sx, remote start wiring
Posted By: projekt240
Subject: 1995 Nissan 240sx, remote start wiring
Date Posted: December 12, 2006 at 5:38 PM
heres the story... i have the viper 771 (alarm, remote start, keyless entry)
and i need the wiring schematics for my car (1995 nissan 240sx)
it has an ebay alarm / keyless entry on it now... but the range / efficiency is awful.
thank you. :)
Posted By: Twelvoltz
Date Posted: December 12, 2006 at 6:49 PM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 240SX / 1995 / Remote Start
[PRINT THIS PAGE]
12volts      white       +       ignition harness
Starter      BLACK / YELLOW       +       ignition harness
Second Starter      BLACK/ white       +       ignition harness
Ignition      BLACK/ red       +       ignition harness
Second Ignition
Third Ignition
Accessory      white       +       ignition harness
Notes: When doing remote start, this wire must be isolated from the keyswitch with the accessory relay. See direct fax document #1077.
Second Accessory
Keysense
Power Lock      lt. GREEN / WHITE       -       anti-theft module
Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN.
Power Unlock      brown       -       anti-theft module
Lock Motor
Unlock Motor
Parking Lights+      RED / blue             ignition harness
Notes: There are two (2) RED / blue wires in the ignition harness, one is for parking lights and the other is for the right headlight.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / white       -       harness in driver kick
Dome Supervision
Trunk/Hatch Pin      red       -       anti-theft module
Notes: If not equipped with an anti-theft module, the red wire is located in a harness at the left trunk hinge.
Hood Pin      yellow/black       -       anti-theft module
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      lt. GREEN/ red       -       anti-theft module
Factory Alarm Disarm      GREEN/ YELLOW       -       anti-theft module
Disarm No Unlock
Tachometer      yellow/red       ac      ECM in passenger kick
Wait to start
Brake Wire      RED / green       +       brake switch
Parking Brake
Horn Trigger      YELLOW /GREEN       -       anti-theft module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Here is the tech tip listed for accessory isolation.
