compustar 2wfm range problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88622
Printed Date: April 29, 2024 at 3:52 PM
Topic: compustar 2wfm range problem
Posted By: honduh
Subject: compustar 2wfm range problem
Date Posted: January 09, 2007 at 5:11 AM
I recently installed a compustar 2wfm 2 way remote starter/alarm in my 240sx, and my range is awful. I have a strip of 20% tint across the top of my windshield that comes down about 5 or 6 inches, and I mounted the antenna on the tint, top-center of windshield horizontally. Where should I relocate the antenna to get the range that is normal?
my previous alarm/remote start was a code-alarm 2 way and I had the antenna mounted in the same place, and my range was way better, so I didn't think it would be an issue to use the same mounting spot. Any help is much appreciated.
Posted By: KarTuneMan
Date Posted: January 09, 2007 at 8:12 AM
Below the tint would be ideal.....If you use good quality film, you would know it has metal in it. This will definatly degrade the signal. Maybe try up along the A pilar.
